need help?! aebs head stud torque specs
i tried the search only showed up 3 post didn't help at all
i know the stud itself has a torque spec....then the actual nut has a torque spec too....help would greatly appreciated trying to finalize my swap by puttin my head on thanks again |
I don't want to insult your intellegence, but have you called AEBS themselves to get info? Ben has the information available to you..
Re: need help?! aebs head stud torque specs (GunMETAL_TEgRa)
The stud it self should be 8-10 ft lb's. As for the nut, what motor is this going in?
Re: need help?! aebs head stud torque specs (9sech22civic)
its a b18c1 gsr block...with type R head...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan »</TD></TR><TR><TD CLASS="quote">I don't want to insult your intellegence, but have you called AEBS themselves to get info? Ben has the information available to you..</TD></TR></TABLE> nope i haven't called aebs that why i posted on honda-tech.com knowin someone here had to install these b4 and have the info on hand.... thanks now i just need the specs for the actual nut |
ttt
I could be wrong but i think its 63 ft lb's.
I FINALLY GOT THE INFO...
stock factory pre-stage(first stage) stock factory is 64ft/lbs aebs 10ft/lbs for the actual stud then 30ft/lbs pre-stage then 64ft/lbs thanks to redz0ne performance hopefully this helps anyone else in the future... btw these specs were used on my friends gsr motor and my type R motor |
Since we are on the subject of head studs. I have some ARP head studs. Have the head off, have the nuts off. What I want to know is how exactly you get the studs out of the block? I know it has the hex on the top, and I tried using an alan wrench to get it out, but that beast is stuck in there.
Any special way to get these out? Thanks guys |
Re: need help?! aebs head stud torque specs (95GSRTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">Since we are on the subject of head studs. I have some ARP head studs. Have the head off, have the nuts off. What I want to know is how exactly you get the studs out of the block? I know it has the hex on the top, and I tried using an alan wrench to get it out, but that beast is stuck in there.
Any special way to get these out? Thanks guys</TD></TR></TABLE>use an allen socket thats what i did...i went to sears and got craftmen 3/16 socket allen worked like a charm <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9sech22civic »</TD></TR><TR><TD CLASS="quote">damn only 1 off </TD></TR></TABLE> https://honda-tech.com/forums/images...es/emsmile.gif good stuff....thanks for helpin tho... |
