Bad inline fuel pump?
Old Jul 1, 2004 | 06:04 AM
ITRpwrdEG's Avatar
Default Bad inline fuel pump?
I replaced my FMU thinking it was not working because of maybe a faulty one from the factory, but now I'm questioning the inline fuel pump. It made my fuel pressure higher than normal at idle. 42psi to 60psi with FMU installed. After a day of driving, all of a sudden fuel pressure dropped to stock. So I was a little excited, even though I shouldn't be because what if it just decides to drop to 30psi for example. Sure sh%&. I'm driving and it keeps going from 32 - 38psi. And when i accelerate over 30% throttle or so, it drops about 5psi from wherever fuel pressure is at. I'm thinking I have a faulty Inline fuel pump that's acting like a brick wall not allowing fuel through it cause its not working. Keep in mind that it will no longer increase fuel when boost kicks in. It used to for a little bit, but only reached 80psi max around 5psi.
ideas?
ps-I would have disconnected the fuel pump and rerouted the lines like it was stock, but I didnt have time last nite. I'm just bored at work and want a heads up before i try that.
Old Jul 2, 2004 | 02:35 PM
beepy's Avatar
Default Re: Bad inline fuel pump? (ITRpwrdEG)
Could also be a clogged fuel filter.
SIK IN DA HED
Nov 12, 2003 09:37 AM
importimage
Jul 11, 2003 03:45 PM
wrXtian
Jan 20, 2003 07:49 AM
SpoolnG2
Nov 12, 2002 05:47 PM
5gen-hybrid
Aug 5, 2001 10:17 AM
