NEED HELP
Old Jan 31, 2006 | 11:33 AM
jdm2teg's Avatar
Default NEED HELP
well today when i came home i notice there was lots of white smoke coming inside my car since i dont have an exhaust and just a down pipe. so i looked under my hood and saw white smoke coming out of my breather. also saw oil on my ic piping and little on my battary. what does that mean. i am hoping it is just the head gasket and not the ring landing or anything. thanks for any help.
Old Jan 31, 2006 | 11:48 AM
JDM turbo DC's Avatar
476 whp / 323 tq @ 17 PSI
Default Re: NEED HELP (jdm2teg)
do a compression test or leakdown test, you'll find more specific results. hows ur coolant level? the sign of white smoke seems like the gasket and the oil might actually be from the ringlands, sorry to hear that. good luck to u
Old Jan 31, 2006 | 11:56 AM
jdm2teg's Avatar
Default Re: NEED HELP (JDM turbo DC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM turbo DC &raquo;</TD></TR><TR><TD CLASS="quote">do a compression test or leakdown test, you'll find more specific results. hows ur coolant level? the sign of white smoke seems like the gasket and the oil might actually be from the ringlands, sorry to hear that. good luck to u</TD></TR></TABLE>
dam this is scary. when tha car is running it wasnt spiting oil, only white smoke. so i am guessing only when i floor the gas, it spits oil on my piping. there is no leak on the floor and the motor doesnt over heat also.
Old Jan 31, 2006 | 12:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm2teg &raquo;</TD></TR><TR><TD CLASS="quote">
dam this is scary. when tha car is running it wasnt spiting oil, only white smoke. so i am guessing only when i floor the gas, it spits oil on my piping. there is no leak on the floor and the motor doesnt over heat also. </TD></TR></TABLE>
im sorry about what i said about the oil problem from your ringlands. it actually seems that the oil in your intercooler/charge piping is from blown turbo seals. is there oil in your downpipe/manifold? if so, then that is from bad ringlands.
Old Jan 31, 2006 | 05:28 PM
jdm2teg's Avatar
so u think its jus the headgasket. cus it does spits oil out the breather when i floor the gas. but when i jus leave it ideling it only smokes out the breather. white smoke.
Old Feb 1, 2006 | 07:53 PM
jdm2teg's Avatar
so today i did the compresion test 1#60. 2#150. 3#140. #4 130 now forget worrying about the head gasket. now i have to hope its not my sleeves. i now hope its my ringlanding.
Old Feb 1, 2006 | 08:14 PM
u able to do a leakdown test for that cylider1? compressed air into the cyliner, you can check to see if its the valves or ringlands.
Old Feb 1, 2006 | 08:41 PM
jdm2teg's Avatar
i dont have time since i started going to college. i will do that on friday. thanks for the help man.
Old Feb 1, 2006 | 08:48 PM
when the air is compressed on that cylinder, listen closely. if you hear air coming out of your throttle plate when you open it then its your intake valves/seals. if you hear air coming out of your tailpipe (listen closely to ur muffler), then its your exhaust valves/seals. have the oil cap off and if u hear air out of there, its your rings/ringlands
Old Feb 1, 2006 | 08:50 PM
GOOD LUCK, me and the homeboiz call the leak down test, "the death test" because the bad readings from the test will force the wallet open
Atauto
Honda CR-V & Element
Aug 27, 2016 08:13 AM
93coupe1330
Nov 1, 2009 10:09 PM
Redprelude98
Nov 25, 2008 10:42 AM
Hulk_EJ8
Jun 5, 2006 12:43 PM
froggie3kb
19
Oct 30, 2003 06:15 PM
