Need help!!!!!!!!!!!!!!!!!!11
Old Jun 2, 2003 | 04:28 PM
adhana2's Avatar
Default Need help with the ecu (safc)!!!!!!!!!!!!!!!!!!!
I was installing my safc, but it was messed up and didnt work. I had no wriring harness, so i tapped into the ecu harness by shouldering it and now my car wont start? There is no voltage reading on the wire. let me know thanx
and i have a obd2 p72 chip for a 2000 GSR if some1 has the manual plez let me know what fuse the yellow with black line wire goes 2 thanks
Modified by adhana2 at 9:13 PM 6/2/2003
Old Jun 2, 2003 | 05:16 PM
adhana2's Avatar
Default Re: Need help!!!!!!!!!!!!!!!!!!11 (b3435)
naw not sellin it...but i seriously need to get my car workin agin...some1 help me out
Old Jun 2, 2003 | 05:31 PM
adhana2's Avatar
yea i disconnected the battery and reconnected it...and i took my safc off and tried to turn the car on and it still doestn turn on...but the only wire i messed with was the ic power and the ground...the ground works perfectly cuz i tested the volts with the volt meter with teh RPM wire and it give me 12V so itz just the ic power wire that is messed up... mayb loose...ne1 other suggestions or contact that i can contact
jromulo
Aug 19, 2007 11:10 PM
odogg726
Audio / Security / Video
May 28, 2007 10:13 PM
MarkV1184
Jun 24, 2005 10:32 AM
4runner
Jun 10, 2005 03:36 AM
staticrex
Dec 8, 2004 11:46 AM
