Help with power to headunit
Old Jun 24, 2005 | 09:21 AM
MarkV1184's Avatar
Default Help with power to headunit
I have a little problem. Somehow on my 99 EK the power wire going into the wiring harness to my headunit doesn't work. So as a little fix I ran a wire to the battery to power my headunit, but now the problem is that it doesn't turn on or off with the car. For saftey precautions I put a 7.5 amp fuse in between the battery and headunit.
Any ideas as to how I can wire it so that It'll turn on and off with the car?
Old Jun 24, 2005 | 09:55 AM
Bbasso's Avatar
Default Re: Help with power to headunit (MarkV1184)
use the acc wire that went to the stock radio, pretty easy - use a test light and see which wire goes on / off when you turn the key.
Old Jun 24, 2005 | 10:32 AM
MarkV1184's Avatar
Thanks bbasso. I ended up using the cigarette adapter ACC wire to wire it up.
redsled00
Audio / Security / Video
Apr 10, 2009 10:17 PM
4runner
Jun 10, 2005 03:36 AM
4runner
Jun 9, 2005 11:38 PM
cd5_2NR
Apr 20, 2003 09:47 PM
oryanh
Mar 26, 2003 02:00 PM
