Need Garrett turbo help....
Old Feb 23, 2008 | 05:24 PM
wreckmaster678's Avatar
Default Need Garrett turbo help....
I'm trying to figure if this turbo will work on my car. The car is a 1990 Accord. Engine is a jdm f22b, manual trans from a 95 prelude (m2s4 I think) The info on the turbo is as follows. Garrett P/N # 466159-5003 S/N # ffm51231 A/R # .60m24 and there is "-80" stamped on there as well. I'm not so turbo savvy, but know what the acronyms mean, just not how to read them.... I'm not sure if this is the turbo I need or if this is more of a ''B" series turbo. The engine has all stock internals for now. Any ideas???
Old Feb 23, 2008 | 06:54 PM
TheShodan's Avatar
Moderator
that is a "57 trim" turbo, and can work fine for the F22b. tune it, run it, and enjoy.
Old Feb 25, 2008 | 11:47 PM
Default Re: Need Garrett turbo help.... (wreckmaster678)
what would be a safe boost level on this engine? Stock inernals...
Old Feb 26, 2008 | 06:20 AM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckmaster678 &raquo;</TD></TR><TR><TD CLASS="quote">what would be a safe boost level on this engine? Stock inernals... </TD></TR></TABLE>
I've seen F22Bs go through a lot of punishment, and a few die after a few weeks. the car can't take more than about 250whp. So in your case about 7-8 psi
Old Feb 27, 2008 | 06:34 AM
Default Re: Need Garrett turbo help.... (TheShodan)
Hmm..... OK, so if I go with a good set of pistons and rods and some titanium valvetrain etc, What kind of power do you think this engine is capable of? I can only assume that I will have to sleeve the block as well. I'm not sure if it has them already or not.
Old Feb 27, 2008 | 04:46 PM
TheShodan's Avatar
Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wreckmaster678 &raquo;</TD></TR><TR><TD CLASS="quote">Hmm..... OK, so if I go with a good set of pistons and rods and some titanium valvetrain etc, What kind of power do you think this engine is capable of? I can only assume that I will have to sleeve the block as well. I'm not sure if it has them already or not.</TD></TR></TABLE>
The turbo's capability is about 440whp or so, after about 1.2PR (or 17psi), but I would not run at that level all the time, it will shorten the lifespan of the turbo (also depending upon abuse). I mean over a year or 2 for the lifespan of the turbo. With the engine internal modifications you plan, you can go as much as your heart, wallet, and the car can handle.. Its rather a vague question, really..
Old Feb 28, 2008 | 02:29 AM
I see your point. my actual goal was around 350-400 hp. It isn't my daily driver but at the same time I would like something that is somewhat reliable when i need it. I am doing my collection of jdm goodies at the moment, and then engine parts come next. I actually only drive a car to and from work twice a week and even then it's only a 2.2 mile trip. I drive a heavy duty wrecker the rest of the time. my wrecker runs at 30 psi under full boost. on a stock cat engine. its kinda crazy, lol...
Bt the way, I wanted to have the exhaust side of my turbo ceramic coated, and found a shop that will do it for $65, but he can't or won't do the aluminum compressor side. What to do? It will unbolt in the center of the housing, but I will have to take either one or both of the turbine's off and i'm a bit leery about doing that. What is your advice oh wise and honorable one?
ludeking1007
Aug 17, 2009 08:33 AM
robbizza
May 21, 2006 02:17 PM
PnoyJeff
Jan 26, 2005 03:22 PM
Briman2021
Oct 28, 2003 08:34 AM
cyberx
May 20, 2002 10:06 AM
