need DIY info for coil on plug
Old Oct 25, 2006 | 04:43 AM
allhonda's Avatar
Default need DIY info for coil on plug
does anybody knows or has any info on how to do coil on plug conversion on the B motors, i would like to try it out!!!
Old Oct 25, 2006 | 04:48 AM
96 GSR-T's Avatar
Default Re: need DIY info for coil on plug (allhonda)
Searching owns you, I know I shouldnt be saying that but there is tons on info archived.
Old Oct 25, 2006 | 04:54 AM
allhonda's Avatar
Default Re: need DIY info for coil on plug (96 GSR-T)
hey i did but i only found one post about it thats why im asking...
Old Oct 25, 2006 | 04:55 AM
96 GSR-T's Avatar
Search Coil On Plug and click Archived, I came up with 47 hits.
Old Oct 25, 2006 | 04:56 AM
96 GSR-T's Avatar
Here is a nice one....
https://honda-tech.com/zerothread?id=1344468
Old Oct 25, 2006 | 08:57 PM
allhonda's Avatar
Default Re: (96 GSR-T)
thats is greaty info, so far it answer my Q, i wanted to know if it could be done with hondata this guy says it cant that kind of sucks!!!!
Old Oct 25, 2006 | 10:00 PM
chasemyhonda's Avatar
B A N N E D
nope Hondata has only 1 ignition output.
Old Oct 26, 2006 | 04:09 AM
96 GSR-T's Avatar
Default Re: (blindingxenon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blindingxenon &raquo;</TD></TR><TR><TD CLASS="quote">nope Hondata has only 1 ignition output.</TD></TR></TABLE>
I second that, I have an S300 and if I could run COP, it would be on there already.
Old Oct 26, 2006 | 01:00 PM
allhonda's Avatar
i wouldent be surprise if they start giving you that option, now if they do i think nobody would need an AEM EMS. i found the posts on pgmfi.com and were a couple of guys who made up a board that would make everything work but i think it would be a lot better if it came in lets say the s300 so we could fully tune it to its max!!!
Old Oct 26, 2006 | 02:13 PM
96 GSR-T's Avatar
Default Re: (allhonda)
Having only 1 output in the stock ECU is the problem, I am no expert but I would think Hondata, Crome Etc would have to move to an actual ECU and not modify the stock one.
Old Oct 26, 2006 | 02:39 PM
B A N N E D
unless they put there minds together and figure out how to take that one output signal and make into 4 or 2 channel ignition.
If they can take old sensors and make then to control Nitrous and launch controls then how can they not figure out how to expand the ignition
Old Oct 26, 2006 | 04:11 PM
96 GSR-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blindingxenon &raquo;</TD></TR><TR><TD CLASS="quote">unless they put there minds together and figure out how to take that one output signal and make into 4 or 2 channel ignition.
If they can take old sensors and make then to control Nitrous and launch controls then how can they not figure out how to expand the ignition</TD></TR></TABLE>
I hope they are reading this.................
turbozc03
May 3, 2013 10:57 PM
mtber
Engine Management and Tuning
25
Apr 28, 2013 04:43 PM
mtber
Feb 7, 2013 07:13 PM
shanebadoo
Sep 19, 2012 06:10 AM
mtber
30
May 23, 2011 10:51 AM
