need boost advice
Old Nov 3, 2011 | 08:50 AM
MntlKase's Avatar
Default need boost advice
I'm working on my first boost build and could use some advice. I'm building a f22a for my accord and was wondering what a safe yet semi-aggressive boost level would be to run. Here is my setup:
f22a block bored to 85.5mm
wiseco pistons (9:1:0 CR)
Bisimoto h beam rods
OEM Honda bearings throughout
arp rod and headbolts
stock crankshaft
Ported drag manifold
Holset hx35 Turbo
Hks blow off valve
Tial wastegate
And a built head.
I guess what I'm asking is what in your opinions can the f22 sleeves handle? I've done lots of research and found lots of different answers. Here is a pik:
Old Nov 3, 2011 | 08:57 AM
cleansi's Avatar
Default Re: need boost advice
boost psi has nothing to do with it.
20 psi out a 18g and a gt42r are completly diffrent
think in hp levels
with that being said stock sleeves in a Fseries are very weak it all in the tune you sould be able to achieve 300-350 safely on pump any higher i would search alternative measures for fuel and keep a conservitive tune
Old Nov 3, 2011 | 08:59 AM
MntlKase's Avatar
That's all I'm really shooting for is 300 Ish. I don't see more than that being anymore than a bragging right.
Old Nov 3, 2011 | 09:07 AM
phat00civic's Avatar
20 psi out a 18g and a gt42r are completely different
think in hp levels
with that being said stock sleeves in a Fseries are very weak it all in the tune you should be able to achieve 300-350 safely on pump any higher i would search alternative measures for fuel and keep a conservative tune
+1 on that comment!
10 PSI on one will get you to a different HP level then 10 PSI on the other. I would stick around 300 - 320 though with a good A/F.
Old Nov 3, 2011 | 06:35 PM
putnitdwn4honda's Avatar
Hey i have a idea! Why dont you call Bisimotos? Is he not the expert on the f's...
Old Nov 7, 2011 | 04:39 PM
DeeC2's Avatar
10 Year Member
yo i had one at 415 DD and it was no prob for the block to handle it. i love the single cam.
Old Nov 7, 2011 | 04:43 PM
Schister66's Avatar
Man U FTW
That's a pretty stout setup for 300whp. Since it's built and you have a relatively large turbo, I would actually shoot for ~350-375whp honestly. It is certainly within reason. Fuel will be the limiting factor...are you running pump? E85?
collinsvc15
May 28, 2011 08:27 AM
ek-j
12
Jul 28, 2008 08:04 PM
pbomers
Oct 11, 2005 07:59 PM
Nikoli
May 30, 2004 07:31 AM
cjames235
Aug 23, 2002 11:02 AM
