Boost Falling Off??? - (datalogging graph included)
Old Oct 10, 2005 | 10:46 AM
pbomers's Avatar
Default Boost Falling Off??? - (datalogging graph included)
I'll give you guys a little background on the motor, turbo, etc to help you get an idea of the problem we are having.
D16Z6
8.5:1 Pistons
Eagle Rods
ARP Headstuds
Stock Head
Apexi Turbo Kit
Internal Wastegate (5 psi)
Stock Apexi downpipe
2.5 in. Exhaust
TurboXS High Performance Boost Controller - Set to 15 psi
The problem we are having is getting the car to hold boost. I've included a datalogging graph below to help show what I'm talking about.
The boost slowly falls off after it hits 15 psi. We've checked and are pretty sure there aren't any boost leaks. I've only got one other idea.
The stock wastegate can't handle that much psi even with a boost controller. Some people have said you can double the stock internal wastegate psi before you start having problems. I can get the boost controller for hold 10 psi.
Does anyone have any other ideas? Let me know if you need any other information!!!
Thanks for any info/help!
-P
Old Oct 10, 2005 | 10:48 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: Boost Falling Off??? - (pbomers)
its probably just the turbo cant keep up with the airflow requirements of the motor
Old Oct 10, 2005 | 10:50 AM
non-VTEC's Avatar
ya i think trying to more than double what the stock wastegate is pre-set to will cause that problem........just keep it under 15psi and you should be ok.....or change your pre-set wastegate setting.
Old Oct 10, 2005 | 11:19 AM
B6tPoweredMx3's Avatar
Default Re: Boost Falling Off??? - (non-VTEC)
Sounds like tiny turbo syndrome.
I know, I have it to.
Old Oct 10, 2005 | 02:03 PM
SOHC_MShue's Avatar
Its probably that wastegate.
Old Oct 11, 2005 | 12:28 PM
KevronsEG's Avatar
Default Re: Boost Falling Off??? - (SOHC_MShue)
anybody have any ideas?
Old Oct 11, 2005 | 01:29 PM
EK k kay's Avatar
Default Re: Boost Falling Off??? - (IAmTheRealKevron)
It's probably a small turbo like the one in the Greddy kit and you're pushing it out of its efficiency range with 15psi.
Old Oct 11, 2005 | 03:01 PM
Tony the Tiger's Avatar
It's the internal wastegate actuator. The wastegate is being blown open at higher exhaust pressures.
A stiffer wastegate spring will solve that problem.
Old Oct 11, 2005 | 06:17 PM
yee SERIOUS's Avatar
time to go externaal wg
Old Oct 11, 2005 | 07:31 PM
splitime's Avatar
Sounds just like my 14b problems (although i was also getting massive spiking on the unported internal). I went with an audi 5000 external gate grafted onto my HF manifold... that in combination with stiffer spring and an EBC fixed my issues.
Old Oct 11, 2005 | 07:59 PM
SOHC_MShue's Avatar
Default Re: Boost Falling Off??? - (splitime)
Hf manifold + external gate is the way to go
BlUAc
May 20, 2006 09:43 AM
jonnybravo
Aug 1, 2004 06:01 PM
T-RO
Jun 28, 2004 04:16 PM
FUP23
Sep 30, 2002 09:15 PM
Snafu-Si
Mar 5, 2002 02:07 AM
