need advice on a nitrous setup please....
Old Jun 25, 2003 | 02:52 PM
EFb18b's Avatar
Default need advice on a nitrous setup please....
I have a b18c1 block with 84mm sleeves, 2.0L stroker kit, 9.0:1 c/r, ss valves, double springs, and t66 turbo. I want to slap some go-go juice on her *** during a 1/4mile run and I need some advice on if I should change anything on my setup to make it more "nitrous friendly", how many shots I should run it on, what kind of setup would be best for this etc..
Any advice is well appreciated, thanks.
Old Jun 26, 2003 | 02:29 PM
EFb18b's Avatar
Default Re: need advice on a nitrous setup please.... (Redlineracer)
well this sux anyone?....anyone?....
Old Jun 26, 2003 | 03:37 PM
MercenaryForHire's Avatar
Set aside some extra coin for a new clutch, because you will burn yours out.
Clutch, spark plugs, and head gasket are usually the first things you'll look into. Possibly a fuel pump or pressure valve.
Far as what kit to get? Nitrous Express (NX) Single Nozzle wet kit. 50-shot is plenty.
- M4H
Old Jun 26, 2003 | 03:53 PM
boosted92's Avatar
Default Re: need advice on a nitrous setup please.... (MercenaryForHire)
No offense, but that's a really dumb idea. I'd bet money that you're nowhere near maxing out a T66, nor are you getting into the compressor's peak efficiency range. Screw the ntirous, and crank up the boost.
xfrankx
Feb 6, 2005 01:16 PM
JdmH22Acorn
Feb 3, 2003 07:29 PM
Jeff C
Sep 1, 2002 04:42 AM
FD3S
Aug 17, 2002 08:09 AM
