N2o question
Old Jan 21, 2004 | 08:32 AM
DOHC hatchback's Avatar
Default N2o question
I just got a Nos n2o dry kit for my b16 hatch. Do I have to have a aftermarket fuel pressure regulator? becuase from what i read the "dry kit"tricks ur car into dumping more gas Im only going to be running a 50 shot at most.
Old Jan 21, 2004 | 08:38 AM
Kataku2K3's Avatar
Default Re: N2o question (DOHC hatchback)
I would just stick with the stock regulator... The thing about the cheaper aftermarket ones (Ericks, B&M, etc.) that modify the stock regulator is they contain a rubber gasket which when placed under nitrous pressure can sometimes pop... It really isn't all that bad even in the rare instances that they have popped as you can just get a new gasket... STOCK will work fine in your situation, just my $0.02
Old Jan 21, 2004 | 09:42 AM
Default Re: N2o question (Kataku2K3)
Thanks Btw is a dry shot safe for my car? I know one is safer than the other. Im new with nitrious and I dont feel like blowing a b16.
Old Jan 22, 2004 | 05:20 PM
ttt
Old Jan 22, 2004 | 05:47 PM
turbolshatch's Avatar
Default Re: (DOHC hatchback)
you shouldnt have a problem with a 50 shot. dry kits are very safe
Old Jan 22, 2004 | 07:27 PM
psi420's Avatar
Dry kits are relatively safe.
But I would find a better way to provide the fuel....FPR trick just doesnt do it for me.
Direct Port is the safest IMO.
Then Wet, Then Dry
You need to make sure there is plenty of fuel and spark.
Old Jan 22, 2004 | 07:32 PM
redboost10's Avatar
Default Re: (psi420)
if i had a camera here i could show you what not enough fuel does...
lets just say my piston kinda has a cone look to it, the sides are melted down and theres holes through where the rings go. BUT it was sun!!!
Old Jan 23, 2004 | 08:04 AM
RyanEJ8's Avatar
Default Re: (tgh99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">if i had a camera here i could show you what not enough fuel does...
lets just say my piston kinda has a cone look to it, the sides are melted down and theres holes through where the rings go. BUT it was sun!!!</TD></TR></TABLE>
What did you do to it?
Old Jan 23, 2004 | 08:10 AM
redboost10's Avatar
Default Re: (RyanCivic2000)
it ran lean, broke the little tip off the spark plug and melted the sides of the piston.
Old Jan 23, 2004 | 08:25 AM
RyanEJ8's Avatar
Ouch. I ran lean on a 100 shot and blew the headgasket and melted my spark plug. I had SRP pistons and rings and Eagle rods and they held up. I slapped on a new headgasket and now decided to go with boost and maybe a smaller shot of nitrous 35-55hp.
99civ
10
Jul 6, 2004 11:32 PM
Rory Breaker
Jan 21, 2003 08:23 PM
EFing8
Dec 19, 2002 07:59 PM
Phat_GSR
Sep 11, 2002 06:52 PM
