N20 Problems on the Dyno...
Old Oct 14, 2003 | 01:15 PM
  #51
laughinxxx's Avatar
New User
Default Re: N20 Problems on the Dyno... (RyanCivic2000)
Alright, then check for clogs in the lines, filter, and nozzle. The last thing to do would be to swap out the barney box for one that you know is good. If that doesn't fix any of it, I'd get another fill and make sure that their supply bottle is full or close to it. Finally, I'd try to see if the Zex and Hondata aren't getting along.
Old Oct 15, 2003 | 05:00 AM
  #52
Mista Bone's Avatar
D Tranny Guru
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
Pickup tube was positioned right. They filled the bottle using the gravity method and they chilled the bottle for an hour before hand. I'm thinking about going to this other place nearby that uses a pump. Think that is the problem?</TD></TR></TABLE>
WHAT??????
No way can you get more than 7-7.5 lbs of Nitrous in a 10 lb bottle without a pump.
Also the your supplier might have gotten a new style "big" bottle that has a pickup tube and doesn't need flipped upside down.
Old Oct 15, 2003 | 06:40 AM
  #53
RyanEJ8's Avatar
Default Re: N20 Problems on the Dyno... (Mista Bone)
I will be weighting the bottle when I go to check all my lines this weekend. I had no idea you could only get 7 lbs in that way. Even if it had 7 lbs in though I would have thought it would have worked better than it did.
Old Oct 15, 2003 | 06:58 AM
  #54
Mista Bone's Avatar
D Tranny Guru
not to be harsh..........
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I would have thought it would have worked </TD></TR></TABLE>
That is the last thing you wanna say when spraying.
How did the plugs look??????
Lean 85 shot, fuel at 40 psi. I run 45 psi now..........
Old Oct 15, 2003 | 07:26 AM
  #55
RyanEJ8's Avatar
Plugs were a light tan. It went a little lean on the first couple thousand rpm, for the 100 shot. On the 75 shot and 55 shot the air/fuels were fine.
Old Oct 19, 2003 | 11:56 AM
  #56
RyanEJ8's Avatar
Went outside to check a few things....couldn't find anything wrong. It's doing something different now though. When I hit the purge it comes out nice and snowy and then it dies down and its just air. The bottle wasn't empty because I let off it and then did it again and it did the same thing. Why would it have good nitrous and then die off?
Old Oct 27, 2003 | 07:12 AM
  #57
RyanEJ8's Avatar
UPDATE: After taking out the nitrous line I found a small indent in the stainless steel of the line. I ran my line under the plastic trim on the side of the car and it goes right past the part where I jack it up. I'm thinking that while I was doing my rebuild and putting the car on jackstands I might of got it. Is it possible that a small dent in the stainless could be a whole pinch in the line underneath? A friend told me it's possible that the stainless could have just been dented and the hose underneath pinched. How can I check to see for sure if this is my problem?
Old Oct 27, 2003 | 07:28 AM
  #58
ahobbs's Avatar
HELLO,GOOD MORNIN'
a new line.
Old Oct 27, 2003 | 09:01 AM
  #59
RyanEJ8's Avatar
Default Re: N20 Problems on the Dyno... (HybridcivicLS-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">a new line.</TD></TR></TABLE>
So I should replace the whole line? Is there anyway I can make sure that was the problem?
Old Oct 27, 2003 | 09:05 AM
  #60
ahobbs's Avatar
HELLO,GOOD MORNIN'
Im not sure if you figure out if that was the problem, but i know if i had a pinch in a line i would like to get it fixed just becuase Im picky like that, then you'll know if it was the problem or not.
Old Oct 27, 2003 | 06:22 PM
  #61
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridcivicLS-T &raquo;</TD></TR><TR><TD CLASS="quote">Im not sure if you figure out if that was the problem, but i know if i had a pinch in a line i would like to get it fixed just becuase Im picky like that, then you'll know if it was the problem or not.</TD></TR></TABLE>
I am picky too, but the indent in the line seems really minimal from the outside. If it's not the problem, I don't want to spend $52 on a new line.
Old Oct 27, 2003 | 07:11 PM
  #62
ATS*Mark's Avatar
OG triple OG
so ryan have you figured it out yet?
Old Oct 27, 2003 | 08:12 PM
  #63
RyanEJ8's Avatar
Default Re: N20 Problems on the Dyno... (Hella_JDM)
No, I'm questioning this small indent on the stainless steel line.
Old Oct 27, 2003 | 11:58 PM
  #64
Mista Bone's Avatar
D Tranny Guru
pictures are worth $$$$$$
Old Oct 28, 2003 | 05:46 AM
  #65
RyanEJ8's Avatar
I will get some after work tonight.
Old Oct 28, 2003 | 03:55 PM
  #66
RyanEJ8's Avatar
Digi cam needed recharged. I will have the pics in the morning. Sorry.
Old Oct 28, 2003 | 08:01 PM
  #67
97hb's Avatar
Hey Ryan, where do you have the bottle mounted? I noticed the other day that my zex bottle is real picky where the pickup tube is. I opened the bottle and saw a huge cloud of nitrous, then turned the bottle slightly and it wasn't coming out as strong. I am sure you probably got it right, but you never know.
Old Oct 29, 2003 | 07:59 AM
  #68
RyanEJ8's Avatar
Default Re: N20 Problems on the Dyno... (97hb)
The bottle is mounted in the trunk with the nozzle towards the front of the car.
Here is the pic of the dent in the line. Not very big, but I'm questioning everything at this point.
Old Oct 29, 2003 | 08:05 AM
  #69
ahobbs's Avatar
HELLO,GOOD MORNIN'
Looks like a good size dent to me. but pics are deceiving
Old Oct 29, 2003 | 08:51 AM
  #70
gitwidit's Avatar
hhmmmmm, yo mista?
Old Oct 29, 2003 | 10:27 AM
  #71
Jeff C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">Plugs were a light tan. It went a little lean on the first couple thousand rpm, for the 100 shot. On the 75 shot and 55 shot the air/fuels were fine.</TD></TR></TABLE>
Did you shut the car down in mid spray when you did this or did it idle a little before you pulled the plugs? Btw, that dent does not look like it could cause a prob.
What ocatane are you using?
Old Oct 29, 2003 | 03:44 PM
  #72
RyanEJ8's Avatar
Default Re: N20 Problems on the Dyno... (Jeff C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jeff C &raquo;</TD></TR><TR><TD CLASS="quote">
What ocatane are you using?</TD></TR></TABLE>
I didn't shut the car down mid spray. It was on a dyno. That's how I know my a/f is fine.
Modified by RyanCivic2000 at 1:07 PM 10/30/2003
Old Oct 30, 2003 | 09:06 AM
  #73
RyanEJ8's Avatar
So we got one vote for it could be a problem and one vote for probably not a problem. Anyone else? Mista B?
Old Oct 30, 2003 | 09:14 AM
  #74
twkdCD595's Avatar
have you tried a fresh bottle yet...
nitrous bottles are designed with the bottom of the siphon tube at the bottom of the bottle towards the outlet. Always mount the bottle so that as your car accelerates, the liquid flows toward the pickup tube. as long as your is like this your ok there.
the line looks boarder line to me... it is a restriction in the line no doubt but enough to cause the problems I am not sure.
honda3x23
Apr 25, 2006 02:25 PM
integranator
Dec 22, 2002 02:58 PM
EFing8
Dec 19, 2002 07:59 PM
EGkTiOn_CiViC
Oct 11, 2002 06:31 AM
TypeR1558
Jun 21, 2001 04:35 AM
