My weekend at fun ford.
Just a guess...
Because the pressure build up is so high that it needs a wastegate to relieve the pressure. A BOV can not handle and relieve the pressure fast enough, but the wastegate can.
Am i a winner?
-deepsi
Am i a winner?
-deepsi
Smarter than you
because its not a BOV. it IS a wastegate.
on the charge pipe!
My sarcasm isn't obvious enough I guess...
on the charge pipe!My sarcasm isn't obvious enough I guess...
good job though figuring it out
This is the only thing I could figure out about the WG on the charge pipe. As you can see these turbos are large enough to make a plane fly and require alot of spool. What they do is boost the turbo on the exhaust manifold to lets say 60+psi and use the WG on the charge pipe to regulate it to around 40psi. In this case they dont have to respool the turbo during a shift and no boost is lost.
They use a boost solenoid to controll this at different speeds.
That BOV is huge. Looks allmost like a wastegate...
Hmmm, spool 60psi, but use a WG on the chargepipe to regulate it at 40....now why didn't I think of that?!
They must go thru turbos every other run?
, we were actually considering doing this on the race car, but since we can't get traction it really do much good. Plus, you can run the turbo past it's effieciency threshold and the air gets too hot. Not something you have to worry about when your turbo is as big as our motors.
Thats right, the only draw back I could think of was the heat. But when you use a large turbo like that at high boost levels you wouldnt see as much heat vs. a smaller turbo.
art
art
