My Turbo Setup Is Using Oil!
Old Dec 29, 2002 | 04:59 PM
slowcivic's Avatar
New User
Default My Turbo Setup Is Using Oil!
I have a Turbocharged GSR engine ( fully built ) running 9 to 1 compression and 12psi daily. I have noticed that the engine uses about 1/4 of a quart of oil each day. My driving mostly consistes of commuting to and from work ( about 60mi daily ). Does this oil comsumption sound right? If not, what should I check? Thanks.
Old Dec 29, 2002 | 05:55 PM
First Gen Man's Avatar
Default Re: My Turbo Setup Is Using Oil! (slowcivic)
we need more info.. does it smoke? does it leak ? what else is going on ? becuase that is a lot of oil a day ..
Old Dec 29, 2002 | 06:48 PM
slowcivic's Avatar
New User
Default Re: My Turbo Setup Is Using Oil! (First Gen Man)
When I go to a high rev ( in a gear ) and then take my foot off the gas, I notice blue/white smoke coming out my tail pipe for like 2 sec. No leaking that I can see.
[Modified by slowcivic, 7:49 PM 12/29/2002]
Old Dec 29, 2002 | 08:16 PM
SiRkid's Avatar
thats NOT good
Old Dec 29, 2002 | 11:55 PM
DA MUGEN 1's Avatar
Default Re: My Turbo Setup Is Using Oil! (94hondahybrid)
It could be a few different things but I'll give you three ideas to look for 1.Check your spark plugs do they have oil on them? 2.It could be a seal in your turbo leaking oil into somewhere it is not supposed to go! 3.Double check and make sure their is absolutely no oil leaks
Old Dec 31, 2002 | 01:38 PM
pornstarSR's Avatar
usually when you let off the gas and go full vacuum and see grey oil smoke thats the rings.
Old Dec 31, 2002 | 02:23 PM
KC GSR's Avatar
Default Re: My Turbo Setup Is Using Oil! (pornstarSR)
i'm having a similar problem except my smoke is white and does it a lot...no oil drips on the ground. My oil return line leaks where the fitting connects to the turbo cartridge, but its just wet...doesnt leak enough to drip to the ground
Old Jan 1, 2003 | 11:08 AM
underpressure02's Avatar
I have the same problem. I drive about 200 miles a day and go through 2 quarts a week. I have no leaks at the engine,and when I start the car and let it idol I do not see any smoke coming out. The only time I see stuff come out the exhaust is when I jump on it i usually see a black puff come out (carbon) I am thinking. But I have yet to see oil coming out. Any help would be great. Thanks
Old Jan 1, 2003 | 12:01 PM
SiRkid's Avatar
thats NOT good
Im pretty sure he already knows that.
why dont you relax instead of busting out the hammer.
[Modified by SiRkid, 9:01 PM 1/1/2003]
Old Jan 1, 2003 | 01:06 PM
CRVRX's Avatar
Default Re: My Turbo Setup Is Using Oil! (SiRkid)
Don't panic too soon, It could be few things using oil.
It could be the turbo for one.
While the engine is idling, feel the vent on the valve cover. It should feel like it's sucking and blowing in at the same time.That will give you an idea if it is the oil rings. Also, check the vacume , you should have 18-22 "HG.
duf2570
Sep 2, 2013 03:41 PM
vg7z
Nov 29, 2006 06:08 PM
dirtySOHC's
Apr 27, 2003 03:20 PM
TurBoXBirD16
Jul 31, 2002 09:07 AM
sushibug
Jun 10, 2002 11:07 AM
