my turbo setup!
Old Mar 19, 2005 | 02:29 PM
civicdx1's Avatar
Default my turbo setup!
my car is a 98 civic with a stock 00 b16a2. ok this is what i got so far; drag kit t4to3e 57 trim with tial wastegate,blits dual blowoff valve,walbro 255 intank fuel pump,autometer boost gauge,apc oil gauge,greddy boost controller profec II,obd2a-obd1 conv harness,p28 ecu chipped with uberdata base program,and just waiting for my rc 550 injectors.is there anything else i need?how much hp would i make?im looking to make 250 -300 hp. also got a 8lbs aliminuim flywheel,and stage 2 clutch.fuel pressure gauge.
Modified by civicdx1 at 12:09 AM 4/25/2005
Modified by civicdx1 at 12:10 AM 4/25/2005
Old Mar 19, 2005 | 04:22 PM
HiProfile's Avatar
Default Re: my turbo setup! (civicdx1)
fmic, 3inch exhuast, car alarm.
The 3 things people overlook for making power...and keeping in your possesion.
You might not need a 3inch dp/exhaust since you're probably used to winding out the b16, but anything that can help increase lowend torque on a b16 is worth it's weight IMO.
Old Mar 19, 2005 | 04:31 PM
civicdx1's Avatar
Default Re: my turbo setup! (HiProfile)
i have a sparco fmi,already have a alarm,and 2.5 custom exhaust.anything else i might need??
Old Mar 19, 2005 | 04:38 PM
f22b2tdave's Avatar
wont the 3" kill the lowend torque?!?! i could have sworn larger diameter exhausts kill lowend...
Old Mar 19, 2005 | 05:55 PM
11SEC CIV's Avatar
Default Re: my turbo setup! (f22b2tdave)
clutch? stk si clutches are horrible!!
your whp goals are definelty attainable w/ your set up at probably 8-9 psi
250ish IMO
are u using stk drag mani?
Old Mar 19, 2005 | 06:00 PM
civicdx1's Avatar
Default Re: my turbo setup! (12SEC CIV)
using the drag manifold.any more input?thanks
Old Mar 19, 2005 | 06:27 PM
wantboost's Avatar
Who is Mr Robot?
sounds like all you are missing is a clutch
93turbo16's Avatar
I would definitley get a clutch. ANd then take it to get tuned. Looks like a decent list you got there.
Old Mar 19, 2005 | 06:30 PM
civicdx1's Avatar
Default Re: (93turbo16)
any recomemdations on which clutch to get?thanks . 93turbo16,wantboost
Old Mar 19, 2005 | 06:32 PM
93turbo16's Avatar
I like pretty much any 6 Puck. I would say sprung ACT.
Old Mar 19, 2005 | 11:49 PM
civicdx1's Avatar
upppppppppppppppppp!!
Old Mar 20, 2005 | 06:58 AM
TheShodan's Avatar
Moderator
Default Re: (civicdx1)
Port that wastegate hole slightly to avoid creep in that DRAG Manifold
Old Mar 20, 2005 | 07:56 AM
civicdx1's Avatar
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Port that wastegate hole slightly to avoid creep in that DRAG Manifold</TD></TR></TABLE>any more info on this please.
Old Mar 20, 2005 | 08:06 AM
Tchleung's Avatar
He jsut means whon the manifold before the wastegate goes in. There will be the hole for the exhaust gases to travel. You should port that hole out a bit bigger to help flow to the wastegate even more as some people have boost creep issues with the DRAG manifold.
Old Mar 20, 2005 | 05:07 PM
civicdx1's Avatar
Default Re: (Tchleung)
can i port this hole my self,or should it be done by a shop?
Old Mar 21, 2005 | 07:39 PM
civicdx1's Avatar
bump!!
Old Mar 21, 2005 | 07:53 PM
Tchleung's Avatar
You can do it yourself if you have access do a dremel or die gridner. somethnig small to get in there.. gotta make it all nice and smooth as well tho.
Old Mar 21, 2005 | 08:44 PM
civicdx1's Avatar
how much hp do u guys think ill be making?
Old Mar 22, 2005 | 08:28 PM
civicdx1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdx1 &raquo;</TD></TR><TR><TD CLASS="quote">how much hp do u guys think ill be making? </TD></TR></TABLE>
Old Apr 24, 2005 | 03:09 PM
civicdx1's Avatar
back from the dead!
imsebtactular
Apr 18, 2008 09:11 AM
creepgunner
Mar 20, 2006 06:58 AM
93DituneEX
Feb 6, 2006 05:20 AM
Turbo D' Sol
May 7, 2004 05:49 PM
