My turbo hits the block?
Screw you guys, I'm... going... home.
You certainly don't want to tighten it down all the way if it is hitting the block 'cause that could really mess something up. Can you just use a manifold flange off ebay with a second gasket and longer studs to move it away from the block another 1/2" or so? That might work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjbizzo »</TD></TR><TR><TD CLASS="quote">You certainly don't want to tighten it down all the way if it is hitting the block 'cause that could really mess something up. Can you just use a manifold flange off ebay with a second gasket and longer studs to move it away from the block another 1/2" or so? That might work. </TD></TR></TABLE> Do you have pictures of this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BioXide02 »</TD></TR><TR><TD CLASS="quote"> Do you have pictures of this?</TD></TR></TABLE>
Sorry, no. But go to ebaymotor's turbocharger section and you'll see the header flanges for sale on almost every page.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">It tightends dowm just fine, nut the compressors corner hit the blocka little bit</TD></TR></TABLE>
The problem is that you might be putting a WHOLE LOT of stress on the compressor housing, center cartridge, exhaust housing, manifold, etc. Maybe enough to deform it or crack it now, or later when it heats up, or possibly cause gasket sealing problems. It's just plain bad mojo to risk something like that. I'm just trying to suggest a fairly cheap, easy, obvious, reversible solution, so long as it doesn't push the turbo into the radiator with the extra 1/2". Good luck
You gotta grind the block, all the spacer crap is not good for reliability because you would have 4 more seals that need to stay intact and you have moved the turbo away from the block, giving it more leverage to yank on the studs. I would just grind it until you have at least 1mm of clearance to allow for any expansion and be done.
I had the same problem. I had RenoRacing make me a manifold. He did it for a great price and was really helpful. If things go south, talk to him
But on one side, the turbo actually wont it. Put the compressor housing on the drivers side. It shouldn't hit the block then. But if you're going internal wastegate, you'll have some clearance issues. Also, making the DP will require some sharp bends as well.
It should work on the drivers side though. Keep us updated.
.But on one side, the turbo actually wont it. Put the compressor housing on the drivers side. It shouldn't hit the block then. But if you're going internal wastegate, you'll have some clearance issues. Also, making the DP will require some sharp bends as well.
Just get a $20 angle grinder from http://www.HarborFreight.com and grind it some. It's no big deal, I took a HUGE chunk off my block/webbing, and it's good to go.
