My Track Times.
Old Jun 9, 2006 | 07:16 PM
HamiltonRex's Avatar
Default My Track Times.
I went 13.9 @ 108mph with a 2.4 60ft.
Setup is a GSR in full interior CRX @ 7psi. That was on street tires.. I only got 1 pass in that night (first pass ever on the boosted setup) Then it rained.
I have my 22x8x13 slicks.. and my Lenso's will be here monday.
Im hoping for high 12's with slicks and more seat time.. Any hopes ??
Old Jun 9, 2006 | 08:07 PM
jsw_1986's Avatar
Default Re: My Track Times. (HamiltonRex)
I think your 60' time should be quite a bit lower... probably around a 1.8 or 1.9 but once you get that down you should be good for some low 13's, but unless you raise the boost I don't think you'll be hitting the 12's.
Old Jun 9, 2006 | 08:09 PM
eg crunkmonster's Avatar
Default Re: My Track Times. (jsw_1986)
ur trap is high enough for mid to high 12s if u get ur 60' times down to 1.8-1.9
Old Jun 9, 2006 | 08:13 PM
JDMs1eeper's Avatar
with slicks you'll run EASY 12's. I used to run a consistant 12.6-12.7 @ 106 on slicks w/ a stock LS turbo setup on 6psi
good luck
Old Jun 9, 2006 | 09:42 PM
97turboteg's Avatar
Default Re: My Track Times. (JDMs1eeper)
speaking of this, i just ran a 14.2 @ 106.50 last week. With a horrible 2.5 60ft. I gotta work on slipping the clutch or something, just getting off the line. But you think i could be in the low 13's or high 12's with slicks and no lsd?
Old Jun 9, 2006 | 11:11 PM
adseguy's Avatar
Default Re: My Track Times. (97turboteg)
depends on the car. He stated a CRX so that's thelightestof them all....I love being drunk. My SE (full everything but the god damn engine) rana 12.9 with a 2.0 60' at 110. retty normaql considering I weigh 2700 with me in it
Old Jun 10, 2006 | 06:27 AM
black98gsr-t's Avatar
im in the same boat.. ... i run a 13.9@107.8 with a 2.32 60ft i get so pissed but with slicks a 106-108mph should get u into the high 12s..
Old Jun 10, 2006 | 07:00 AM
coneheadsracing's Avatar
Default Re: My Track Times. (black98gsr-t)
MPH are great, assuming there accurate. I went 13.003 at 109 mph. 92 Hatch, fully lightened, on khumo street tires. So you can def get lower then that. I found that launching at 3500 was a good area for rpms. Then its just modulation of the pedal through second. More seat time will help you, remember your not NA anymore, high rpms aren't going to help you unless you have slicks.
Old Jun 10, 2006 | 06:39 PM
Default Re: My Track Times. (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">MPH are great, assuming there accurate. I went 13.003 at 109 mph. 92 Hatch, fully lightened, on khumo street tires. So you can def get lower then that. I found that launching at 3500 was a good area for rpms. Then its just modulation of the pedal through second. More seat time will help you, remember your not NA anymore, high rpms aren't going to help you unless you have slicks.</TD></TR></TABLE>
I will be on slicks next time, and yes track is very new and hosts many large events im sure its accurate.
Remember everyone this was my first pass EVER!
Old Jun 11, 2006 | 07:03 AM
97turboteg's Avatar
my motors built, and im only running 6psi because of a leaking blow off valve. You think i can get into 12's with slicks although i DONT have LSD?
Old Jun 11, 2006 | 07:10 AM
97turboteg's Avatar
3500 is a horrible place to launch on my car. With a t3/t4, Ill just bog. I still havent found a good spot to launch, imma try slipping the clutch. That outta do the trick
B18C1CYA
Jul 26, 2004 08:15 PM
B18C1CYA
Jul 26, 2004 03:26 PM
Nextelbuddy
Jun 19, 2004 09:32 PM
pagong
May 9, 2002 11:36 PM
