my setup - what kind of numbers?
Old Jan 13, 2007 | 08:18 PM
b16a4's Avatar
Default my setup - what kind of numbers?
what kind of numbers to expect from..
a stock b16a with 7psi T3/T4 Turbo.
greddy bov and tial 38mm wastegate?
Old Jan 13, 2007 | 09:45 PM
oem_dc2's Avatar
Default Re: my setup - what kind of numbers? (b16a4)
220 hp 165 tq more or less
Old Jan 13, 2007 | 09:53 PM
strictly.business's Avatar
Banned
depends on who tunes it.
id say at 9-10 psi you COULD hit 300.
Old Jan 13, 2007 | 09:55 PM
93turbo16's Avatar
Default Re: (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business &raquo;</TD></TR><TR><TD CLASS="quote">depends on who tunes it.
id say at 9-10 psi you COULD hit 300.</TD></TR></TABLE>
EH, that depends on what dyno you are using.
Also I would project anywhere from 210-250. Depending on supporting mods.
Old Jan 13, 2007 | 10:06 PM
Boosted_Coupe's Avatar
I pretty much will have the same setup. My question is, will it be ok to boost at 9-10 psi on a b16a daily driver? I'm getting it tuned by a good tuner.
Old Jan 13, 2007 | 10:07 PM
93turbo16's Avatar
Default Re: (SiR_JDM95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR_JDM95 &raquo;</TD></TR><TR><TD CLASS="quote">
I pretty much will have the same setup. My question is, will it be ok to boost at 9-10 psi on a b16a daily driver? I'm getting it tuned by a good tuner. </TD></TR></TABLE>
You shouldn't have any problems. Just run good gas and be on the safe side with the timing.
Old Jan 13, 2007 | 10:16 PM
Default Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 &raquo;</TD></TR><TR><TD CLASS="quote">
You shouldn't have any problems. Just run good gas and be on the safe side with the timing. </TD></TR></TABLE>
sweet, we have 94 here. I just want the engine to be realiable, but also a weekend track *****!
Old Jan 14, 2007 | 06:49 AM
b16a4's Avatar
i dont have the money for engine management.
would i be safe @ 10psi with a FMU and MSD BTM? and 340CC injectors?
Old Jan 14, 2007 | 07:26 AM
93turbo16's Avatar
Default Re: (b16a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">i dont have the money for engine management.
would i be safe @ 10psi with a FMU and MSD BTM? and 340CC injectors?</TD></TR></TABLE>
To be honest. If you don't have money for the most important part of the turbo process, then you shouldn't turbo your car.
Old Jan 14, 2007 | 07:29 AM
b16a4's Avatar
also, there isnt anyone down here thats a compentant tuner.
and i dont know how to tune a hondata.
Old Jan 14, 2007 | 07:34 AM
93turbo16's Avatar
Default Re: (b16a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">also, there isnt anyone down here thats a compentant tuner.
and i dont know how to tune a hondata.</TD></TR></TABLE>
You would honestly be better off with a chipped ecu and a set of bigger injectors.
If you would get a wideband, you can monitor the tune yourself.
If you have any questions Pm me.
Old Jan 14, 2007 | 08:11 AM
b16a4's Avatar
would the stock fuel pump be fine?
Old Jan 14, 2007 | 08:24 AM
b16a4's Avatar
and i don't see how running on a basemap is any better than fmu.
anyone care to shed the light?
Old Jan 14, 2007 | 08:28 AM
JDogg's Avatar
Default Re: (b16a4)
43
Old Jan 14, 2007 | 08:47 AM
b16a4's Avatar
Default Re: (JDogg)
if i am runnin a fmu with a msd btm to retard timing?
Old Jan 14, 2007 | 08:48 AM
EFvtec Yo!'s Avatar
Your setup is pretty much the same as mine. Stock B16, AEBS intake mani, Drag Manifold, T3/T4 57 trim .63ar, 550cc RC injectors, Walboro 255 pump, Tial 38mm gate with 7psi spring, and full 2.5" exhaust I made 233hp/154tq @ 7 psi. Tuned on hondata s200b.
Old Jan 14, 2007 | 08:51 AM
b16a4's Avatar
Default Re: (EFvtec Yo!)
those numbers seem a bit low .....
or is it supposed to be arround that?
Old Jan 14, 2007 | 09:06 AM
93turbo16's Avatar
Default Re: (b16a4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a4 &raquo;</TD></TR><TR><TD CLASS="quote">those numbers seem a bit low .....
or is it supposed to be arround that?</TD></TR></TABLE>
On 7 psi, that is about right. The numbers varry between what dyno you use.
Old Jan 14, 2007 | 09:29 AM
B18 CYA's Avatar
Also, on an FMU I doubt you will make over 200whp
Old Jan 14, 2007 | 09:58 AM
Banned
this thread is a waste of time.
a ******* basemap has ignition changes, a fmu doesnt. youre going to blow up your car. thanks!
Old Jan 14, 2007 | 01:02 PM
morgan@synapse motorsport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business &raquo;</TD></TR><TR><TD CLASS="quote">this thread is a waste of time.
a ******* basemap has ignition changes, a fmu doesnt. youre going to blow up your car. thanks!</TD></TR></TABLE>
he said an fmu AND a boost retard module.
and if im not wrong an fmu at 7psi would mean like 120psi at the rail wouldnt it? also fmu, and larger injectors dont go together, its meant to raise pressure for stock injectors.
its gonna cost you a lot more money in the long run attempting to do what your trying to do.
you could have saved money and not gotten the fmu, and msd retard module. crome is so cheap to get chipped.
Old Jan 14, 2007 | 01:11 PM
Pnoyej6's Avatar
* B A N N E D *
I made 250whp 200wtq so far tuned with obd1 p28 chipped hondata s300 on 6.5psi with the t3 t4 drag kit on my ls vtec setup. Im gonna up the boost tomorrow and hopefully hit 300+
Old Jan 14, 2007 | 01:24 PM
boosted92's Avatar
Default Re: (b16a4)
If you don't have money for engine management, you don't have the money to replace your shortblock when it blows the expletive up because you cheaped out. End of story.
Old Jan 14, 2007 | 01:26 PM
Synapse Motorsport's Avatar
Default Re: (boosted92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
If you don't have money for engine management, you don't have the money to replace your shortblock when it blows the expletive up because you cheaped out. End of story.</TD></TR></TABLE>
Well spoken
Old Jan 14, 2007 | 01:34 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (Synapse Motorsport)
Just get obd 1 ecu chipped it and tuned with Crome pro. Come on bro.
importsautomotive
30
Feb 28, 2007 05:26 PM
pinoyk20
Nov 2, 2006 07:16 PM
TheGsR99
Nov 6, 2005 06:36 PM
boostjunkie757
Oct 29, 2004 04:41 AM
~B18C5~EmPRE55
Sep 21, 2003 06:09 PM
