my rpm keep on jumping
Old Mar 10, 2004 | 03:39 PM
VtecbOi's Avatar
Default my rpm keep on jumping
i have a 95 honda civic ex turbocharge with the greddy kit with the stock engine and after a few months for some reason the rpm begine jumping. i don't know what's the problem is. even when it's warn up sometime it still do that. it's happening more offen. oh and it doesn't do that when i put it in gear.
Old Mar 10, 2004 | 03:46 PM
JdM_y0's Avatar
ur idle control valve is busted, time for a new 1. same thing happen with my car
Old Mar 10, 2004 | 03:52 PM
VtecbOi's Avatar
Default how much is it
what happen if i keep on driving it ?
Old Mar 10, 2004 | 04:21 PM
-iLLuZioN-B18C1's Avatar
Default Re: how much is it (VtecbOi)
my rpm jumps as well. im thinking it may be electronic error though. may buy new tach to see if still jumps.
Old Mar 10, 2004 | 05:59 PM
D@nnY's Avatar
Fast idle valve or idle air controll causes that ..BUT it can also be air in your coolant ..coolant travels into the fast idle and idle air control ..bleed out the air try turning down your idle screw alittle bit is that doesnt work..if not pull off the upper charge pipe and let the car idle ..look inside the throttle body and you will see 2 holes ..these are the air passage for the idle air and the bottom is for fast idle. if the fast idle is sucking air after the car is warm thats your problem..
Old Mar 10, 2004 | 07:38 PM
turbolsintegra26's Avatar
Default Re: (GSRT37)
To check this problem, take off your upper charge pipe from the throttle body, if you have a huge vacuum leak you'll hear it, and there is a hole in the outter part of your throttle body, if you putt your finger over it and the idle goes back to normal, it is surely your fast idle valve.Ta ke out your fast idle valve below the throttle body, there is a plastic cap that threads in, it will probably be loose. just thread it back in and you should be fine. Good luck
Old Mar 15, 2004 | 09:49 PM
D@nnY's Avatar
didnt i just pos tthat ..god damn ..THANK OYU CAPTAIN OBVIOUS..your my hero
stuckinmud
Aug 14, 2009 08:32 AM
fe519
Nov 8, 2004 06:08 AM
b16acrxer
Aug 31, 2004 09:02 AM
91SE
Feb 18, 2003 04:35 PM
