My POS Intercooler!
Old Feb 4, 2004 | 04:04 PM
SiRkid's Avatar
Default My POS Intercooler!
So yeah. When I started this stuff(boosting) I figured I could save some money buy making my own i/c. Because we all know i/c's cost wayyy too much money.
I had 2 cores and I jb welded them together! w00t! I local buddy said he could get endtanks made for me . So I said sure. they were beautiful and were TIG welded.
At first I noticed a mounting tab had cracked. I then decided eventually I would take the i/c to have it fixed.... cars been away for the winter and today I finally got off my *** to take it off the car.
well looks like I might be having to buy one (but I guess thats good)
the endtanks didnt last that long . The i/c was on the car maybe 6 months and well look at the pics(i think the way I had it mounted probably added some stress but I didnt expect this)
Custom ownz j00
cracked tab
light on outside(cracked)
last 2 pics are with a flashlight inside the outlet.
I shouldnt be able to see the inside of the core from there.
Moral of the story.
MAKE sure you mount your intercooler properly !
Also make sure you get the work done somewhere good!
still dont know if Im gonna fix it or just buy a backdoor pwr from fullrace.
JB weld pwns TIG welding...ahhahhaaa
yeah the cores aint going anywhere.
wierdness
so im guessing thats some major boost leakage.
and im 95% sure I ran at the track this way!
so 14.2@98 on a crud basemap with some major boost leakage
Old Feb 4, 2004 | 05:53 PM
SiRkid's Avatar
Default Re: My POS Intercooler! (SiRkid)
would you fix it or just buy a PWR?
Old Feb 4, 2004 | 07:04 PM
Sinner's Avatar
I'll take it off your hands for 50 bucks :-),.... **** I'd jbwed those cracks. I got the jb weld on my bov and my oil pan, that **** is good.
Nick
Old Feb 4, 2004 | 07:08 PM
Kwuaymaikrup's Avatar
Default Re: My POS Intercooler! (Sinner)
Get one from Earl. I would just to save future headaches.
-Ryan
Old Feb 4, 2004 | 07:13 PM
m R g S r's Avatar
Default Re: My POS Intercooler! (Kwuaymaikrup)
I tried JB welding my intercooler brackets (steel brackets to an aluminum IC, and they cracked off completly within 3 weeks! Then I got some brackets welded for $15, should have done that in the first place!!
Old Feb 4, 2004 | 07:23 PM
SiRkid's Avatar
Default Re: My POS Intercooler! (m R g S r)
everything is TIG welded except for the 2 cores..right down the center it is JB welded
Old Feb 4, 2004 | 07:26 PM
Bailhatch's Avatar
why not just reweld? what kind of cores are they?
Old Feb 4, 2004 | 07:30 PM
spincity's Avatar
your number 1 problem is how the end tanks are made... you are losing potential hp when you make your endtanks like this. ***somthing to remember*** every 90 degree turn you make in your I/C your losing 1 percent hp.. don't use jb for this bring it to a welder to do a good job..
Old Feb 4, 2004 | 09:55 PM
SiRkid's Avatar
Default Re: My POS Intercooler! (Bailhatch)
they are ford i/c's (deisel i/c's)
they were small though.
as for how its made... ?
theres nothing wrong with how its made.(the design)
other then the welding didnt hold.
the ONLY part that is jb welded is right down the center and its held up.
only this ONE side has the TIG weld let go.
howmany times do I have to type that?
Old Feb 5, 2004 | 02:31 AM
TurboTony's Avatar
Just buy one stop being cheap, haven't you learned your lesson.
Old Feb 5, 2004 | 06:49 AM
kKdARIAN's Avatar
Vice President/CEO
Default Re: My POS Intercooler! (TurboTony)
damn bro'... learn from your mistakes, save some $$ and get an IC that you don't have to worry about.
my .02
Old Feb 5, 2004 | 06:50 AM
Nid Styles's Avatar
Just get it fixed. Spend th emoney on something else. Like a bigger turbo.
Old Feb 5, 2004 | 09:09 AM
SiRkid's Avatar
Default Re: My POS Intercooler! (nd_styles)
I dont need a bigger turbo.
lol
still dont know what to do.
I may fix it since I really dont need an i/c thats good for 500 hp at the moment.
hrmmm
Old Feb 5, 2004 | 09:15 AM
hulkhb's Avatar
Tig welding just does break. It looks like he doesn't know how to weld. And also where it looks like morse code, that looks like a incomplete weld, ( i cant really tell - pics suck )
Old Feb 5, 2004 | 09:20 AM
SiRkid's Avatar
Default Re: My POS Intercooler! (hulkhb)
sorry. camera phone.
where it broke it looks like an incomplete weld to me.
(didnt penetrate at all really)
Old Feb 5, 2004 | 10:01 AM
Scott - 93HB Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurboTony &raquo;</TD></TR><TR><TD CLASS="quote">Just buy one stop being cheap, haven't you learned your lesson.</TD></TR></TABLE>
haha, apparently you don't know SirKid!
I wonder if you're cooler's always been like this - if so how the hell were you ever making any boost?
Did you pressure test or water test the cooler after you finished putting the tanks on it???
Old Feb 5, 2004 | 06:16 PM
SiRkid's Avatar
Default Re: My POS Intercooler! (Scott - 93HB Si)
When it was done it was working fine.
where I got the endtanks done. they pressure tested and everything.
the car did move well for a while then it seemed to die. i thought maybe it was cause of a map change but maybe it was this!(it got slow before the spun bearing )
who the heck knows.
all i know is, I either need to fix it or just buy a new one.
anyone wanna buy it? lol.
it doesnt need that much fixing.
Old Feb 5, 2004 | 06:19 PM
TurboJesse
Guest
Posts: n/a
Default Re: My POS Intercooler! (spincity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spincity &raquo;</TD></TR><TR><TD CLASS="quote">your number 1 problem is how the end tanks are made... you are losing potential hp when you make your endtanks like this. ***somthing to remember*** every 90 degree turn you make in your I/C your losing 1 percent hp.. don't use jb for this bring it to a welder to do a good job..</TD></TR></TABLE>
thanks for the post corky bell.
Old Feb 5, 2004 | 08:44 PM
SiRkid's Avatar
Default Re: My POS Intercooler! (Mpir3)
*DEAD*
Turbo-charged
Welding / Fabrication
25
Jan 31, 2006 10:47 AM
boostdummy
Jan 1, 2006 11:08 AM
Soccerking3000
Aug 15, 2004 05:32 PM
Soccerking3000
Aug 15, 2004 05:31 PM
tgreaves
Oct 2, 2003 09:26 PM
