My LS/Vtec Turbo setup for this year.... With pics
Heres the setup
B18a block 81.5mm bore
Wiseco 9.4:1 Pistons
Eagle H Beam rods
ARP Head studs
jdm b16a head
94-01 GSR cams
AEBS Intake MAnfold
RC 750cc injectors
GM 3 bar map sensor
Garrett T304E 60 Trim .63 A/R
TIAL 38mm wastegate..
custom ram style manifold
3 inch DP
3 inch Catback
Precision 350hp intercooler
im lookin for about 350whp with this setup
gonna be tuning with chrome or uberdata...
last pictures N/A
no midwing
new slim fan made this 3 inch DP fitment perfect!
Modified by Topdawgg at 2:14 PM 6/9/2006
Eagle H Beam rods
ARP Head studs
jdm b16a head
94-01 GSR cams
AEBS Intake MAnfold
RC 750cc injectors
GM 3 bar map sensor
3 inch DP
3 inch Catback
last pictures N/A
no midwing
Re: My LS/Vtec Turbo setup for this year.... With pics (StolenTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StolenTeg »</TD></TR><TR><TD CLASS="quote">Nice set-up but where is your dumptube </TD></TR></TABLE>
just put the turbo setup back on 2 days ago... have some little things to do before I get it on the dyno, and the dumptube is one of them..
Re: My LS/Vtec Turbo setup for this year.... With pics (Topdawgg)
you will easily achieve your goals of 350whp range...
where you downpipe means your exhaust turbo housing thats not copper sealant it or it...it will melt right off...if both surface are even its not needed to use sealer...
Re: My LS/Vtec Turbo setup for this year.... With pics (JDM_Risa)
its a VERY high heat silicone, and it is almost even, shouldnt be a problem... just didnt want a small exhaust leak there
Re: My LS/Vtec Turbo setup for this year.... With pics (Turbocivic94)
i have almost the same setup. planning to get 400-450hp with my.
btw you may want to cover up those plates before someone steals your car
deep down i think im gonna make more then that... but im gonna set the goal at 350... but i was really aiming for 400+ with a good tune
what kind of boost will you be running with this similar setup?
i have a ls/vtec W/b16a2 head built boosted @ 21 lbs boost and i make 510whp and 322 ft tq. in eg hatch tuned with apex power f/c by intec racing
run wed night @ pacific raceways went 11.08 @ 130.28 in 1/4
close to same set-up
NIce, Like the stup. But isn't your downpie too close to the radiator. When you launch hard does it hit it?
i cant wait to prove the people around here wrong... nobody thinks i can hit 350whp....
everyday i hear people talkin **** and saying that it cant be done.... its funny
Modified by Topdawgg at 8:22 PM 6/10/2006
Re: My LS/Vtec Turbo setup for this year.... With pics (mr_hahn73)
BUMP
made 322whp and 220 Tq set at 8psi and creepin to 10psi....
once i get the slight boost creep figured out, im goin to 14 to make my goals of 350+
Topdawgg
10-10-2006 09:36 AM
Topdawgg
09-29-2006 04:45 PM
