My ls/vtec turbo setup help!
Old Apr 27, 2009 | 12:51 AM
boosted_DC2_604's Avatar
Default My ls/vtec turbo setup help!
-B18B1 Block
-JE 9:1 Pistons 81.5mm
-Eagle Rods
-ACL main and Rod bearings
-ARP Headstuds and Rod Bolts
-Spun and balanced crank
-Bore and honed
-Polished Crank
-Resurfaced
-Competition Clutch 6 puck
-LS tranny
-Skunk2 Dual Bend Short shifter
-Dyno Tuned on Crome
-B16A2 head
-Resurfaced Cylinder head
-Machined and Heat Bathed
-Skunk2 Cam gears
Turbo Kit:
-T3/T4 Garrett 60 Trim (good for 500HP)
-Blox Manifold
-Tial 38mm Wastegate 1 bar spring
-AEM 3.0 bar map sensor
-AEM Water/Meth Kit
-Denso 660cc injectors
-255 walbro in tank fuel pump
-Synapse BOV
-Precision 350HP Intercooler
-Custom charge pipes 2.5inch
-Custom 2.5inch exhaust
-2.5inch downpipe
-Vibrant Couplers
-T-Bolt clamps
It's makin 331@248 on a mustang dyno, it's pushing 25PSI should i be making more power? or am i maxed out on this setup? If so what should i be changing out first to get some more power? I've had it up to 28-29 PSI without any gains just pushing hot air. Lemem know what you guys think i wanna be makin around 400whp. Thanks in advance.
Old Apr 27, 2009 | 02:51 AM
Civic89stdB16's Avatar
Default Re: My ls/vtec turbo setup help!
look into cams. get at least gsr cams. there can be had for $50-$90 in the classifieds. Ur power seems low. People are making 330whp on stock ls/vtec's with way less boost and no meth kit. There seems to be a bottle neck in ur system somewhere by the power ur posting and the amount of boost. But deff invest in som sort of cams.
Old Apr 27, 2009 | 05:16 AM
Rooftop voter's Avatar
I would say that your down on power, espeicially for the boost that your pushing, but looking at your set up, it seems kinda restrictive. The 2.5 inch DP and exhaust and log type mani aren't helping you any, and you probably want to get a bigger intercooler aswell. Still, for the amount of air your pushing, it still seems low, but I'm not an expert, just my opinion. Change that stuff and I bet you see a huge gain.
alperx
Jun 25, 2012 11:11 PM
mikex1021
Aug 25, 2007 10:09 PM
DC2tuner
Aug 4, 2005 04:15 PM
joepiscapo_83
Dec 1, 2004 08:17 AM
ExplicitSpeed
Mar 8, 2004 10:59 PM
