My ls project
ouch^^^ get that re-welded for sure
hhmmm..... i didn't think twin wg's would be necessary for 500whp. are you going to fix the weld and drill out a new hole for a second wg or are you just going to get a new manifold?
the manifold is my weak point right now. i'll be running a cheap and *free* ss mani for now. I've been thinking about the SPA top mount. cheap and gives you great access to your turbo if you ever need to work on it
gl and keep us posted
yeah i fixed the crack im thinking of getting a new wastgate this one i bought new and put a new diagram in it.it also could be the postion of the wastegate too like other people are saying
finally got a chance to go to the track heres a video of the first pass lot of spin i didn't even get lined up with the black lines but this track is racing in the pit for nascars so its not preped just something to do on fridays and its only two mins from my house.
http://www.youtube.com/watch?v=N6Acvw98GLg
got in a few runs 2night at the track finally broke 7s at this track with no prep work done to it first time was 8.3 if u lokk close i let off before i pasted the finish line lol didn't reliaze it til i watch the video.second run ran 7.9 and thrid run i ran 8.2 missed thrid :-(
http://www.youtube.com/watch?v=10fo2Lyh6gw
went to the dyno on friday to retune with new injectors i was limited to making more hp due to the mani having another crack it we tried to go to 25 psi but it would drop to 20psi
http://www.youtube.com/watch?v=hXsYt5eENiY
well instead of me sleeving my newly built stock sleeve motor i went ahead and purchase naylors sleeved ls motor here is the specs
ERL 84mm sleeves with ERL 5 point main girdle
CP pistons Calico Coated
Manley turbo tuff rods with ARP rod bolts
ACL race bearings calico coated
OEM LS crank with TPR machine work
5.5 quart Moroso oil pain
ARP head studs
im kinda low on cash so i might be selling the stock sleeve motor to cover the cost of any other things i would need
ARP head studs
Build looks good man keep it up
Where did you get your front bumper from? I see it's aftermarket, how's the fitment? I'd like to get an aftermarket 98+ but I'm scared the fitment will be off...
thanks dude i got the bumper from keystone automotive here in fl it fits just like oem it just doenst say integra on the front fits good
[/IMG]
[/IMG]
