my gsr build
Old Jul 26, 2008 | 03:54 PM
methodz55's Avatar
Default my gsr build
i have a gsr ima boost im trying to make around 350hp will it do the job what could be max hp out of this set up?
heres my parts:
gsr block bored to 81.5
npr pistons low comp got free
probe rods got free
balanced crank
type r flywheel
gsr head
pnp
5 angle valve job
supertech valves springs ret
bronze valve guides
type r cams
blox intake mani
type r throttle
arp head studs
oem hg and belt
650 or 660 inj
wal fp
quick 4 mani
gt3076r
tial bov wg
ebay inter
3in exhaust
tuned on neptune
Modified by methodz55 at 8:04 PM 7/26/2008
Old Jul 26, 2008 | 06:41 PM
94delslo's Avatar
Default Re: my gsr build (methodz55)
Considering your parts and that you will be running stock sleeves, I think that from a reliability standpoint you should run no more then 380hp or 400hp. Sleeves are your limiting factor here. Sure you can grab some 1000cc injectors and max the gt30 out around 500hp, but your engine will become a ticking time bomb till you crack a sleeve.
So yeah, you shouldn't have any problem hitting 350hp.
I didn't see a aftermarket map sensor..you should pick up a gm 3 bar and you should be set.
Old Jul 26, 2008 | 07:55 PM
teddy_dc2's Avatar
also clutch, recommend at least 3" exhaust piping, if you want more than 350hp, get sleeves for insurance.
Old Jul 26, 2008 | 07:57 PM
teddy_dc2's Avatar
oops i see u got 3in exhaust already. what kinda turbo mani? i'm taking offers on my sig btw just in case you are interested.
Old Jul 27, 2008 | 08:59 AM
methodz55's Avatar
i have a act 6 puck and a gm 3 bar map im using a spoolin perf quick four ill upgrade to bigger inj what times could i look at in my ek hatch gsr tranny koni yellows and skunk2 coils traction bars im trying to do low 12s high 11s
Eg.ls.turbo
Jan 12, 2013 04:29 AM
ee8_pt
Mar 7, 2011 05:54 AM
methodz55
Jun 7, 2007 12:10 AM
dontgodumb
Nov 30, 2006 06:57 AM
