need turbo help
Old Jul 20, 2008 | 06:40 PM
turbohatch96y7's Avatar
Default need turbo help
well im am planning on boosting my hatch soon but i am unsure on what turbo to but everything else ive got.
well here are my goals
engine b18c1
goals 290-320 hp to the wheels
i am not planning on boosting over 11 psi
i want to keep this reliable and daily driven
i plan to have 2 tunes one for about 230hp and the other up to 320
i want to know which turbo will be good for this goal i dont want to buy a huge turbo because i am not planning to go farther than this goal i am not sure on the size of turbo or brand to buy if somebody can help me choose and direct me in the right way
thanks
Old Jul 20, 2008 | 06:41 PM
Default Re: need turbo help (turbohatch96y7)
oh and i plan on keeping everything stock on the engine except maybe a throttle body and im manifold upgrade
Old Jul 20, 2008 | 06:45 PM
VTECth1s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">well im am planning on boosting my hatch soon but i am unsure on what turbo to but everything else ive got.
engine b18c1
thanks </TD></TR></TABLE>
What's your budget? Do you want a custom turbo kit? Or a pre-made kit? If its your first time, you can go with a pre-made kit. Unless you really know what is needed in a turbo kit.
Old Jul 20, 2008 | 07:02 PM
Default Re: need turbo help (VTECth1s)
im really just looking for the turbo alone i have pretty much a good idea of everything else
Old Jul 20, 2008 | 10:10 PM
blinx9900's Avatar
GT28RS if you are absolutely sure you will never want more than 350whp (which should be an animal on the street), GT3076r if you plan on upgrading in the future...
Old Jul 20, 2008 | 10:15 PM
Rickdrizzle's Avatar
Why not? Anyway, the gurus would often say, "you'd have to base your goal on hp, not psi."
Old Jul 21, 2008 | 07:40 AM
chimmike's Avatar
Default Re: need turbo help (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">GT28RS if you are absolutely sure you will never want more than 350whp (which should be an animal on the street), GT3076r if you plan on upgrading in the future...</TD></TR></TABLE>
again, I'd never start with a t2 framed turbo on the b-series. If you ever wanted to upgrade you'd have to buy a new manifold and downpipe.
get a .57 trim t3/t4, inexpensive and it'll make the power you want with room to go and good top end flow.
Old Jul 21, 2008 | 05:10 PM
Default Re: need turbo help (chimmike)
what does 57 trim t3/t4 turbo mean like the ones that sell on ebay because i only see that name on ebay where can i get this 57 trim t3/t4 turb from exactly if this is what i need for my goals where can i get it from
Old Jul 21, 2008 | 05:13 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">
and thats why i said:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote"> GT28RS if you are absolutely sure you will never want more than 350whp (which should be an animal on the street), GT3076r if you plan on upgrading in the future...</TD></TR></TABLE>
Old Jul 21, 2008 | 05:16 PM
ok thanks for your input so if i buy that turbo everything will be custom to that setup
Old Jul 21, 2008 | 05:31 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks for your input so if i buy that turbo everything will be custom to that setup</TD></TR></TABLE>
well its just that the GT28RS uses a T28 flange so your manifold will have to be a T28 style manifold, if you ever want more power you will have to step up to a T3 flanged turbo so you will for sure need a new manifold and with a new manifold you will need a new downpipe.
Old Jul 21, 2008 | 08:04 PM
TheShodan's Avatar
Moderator
Personally, I like the GT3255b myself. Check my sig for the results with the stock B18C1. See if that helps ya..
Old Jul 22, 2008 | 04:42 PM
Default Re: need turbo help (TheShodan)
what do you mean with out the turbine housing
and whats the diffrence between a oil cooled turbo
and a oil and water cooled turbo is there a big diffrence in cooling
Old Jul 23, 2008 | 10:20 PM
bump help
Old Jul 24, 2008 | 05:18 AM
KeyserSoze's Avatar
turbohatch......
If you ABSOLUTELY ONLY want 300-320whp.
T2 based:
-gt2871
T3 based:
-t3 60 trim
-t3 super 60
-t3/t4 50 trim with the .48 a/r turbine housing
-The turbo mac suggests, the gt32
GL.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">again, I'd never start with a t2 framed turbo on the b-series. If you ever wanted to upgrade you'd have to buy a new manifold and downpipe.</TD></TR></TABLE>
^^^^ I agree.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chimmike &raquo;</TD></TR><TR><TD CLASS="quote">get a .57 trim t3/t4, inexpensive and it'll make the power you want with room to go and good top end flow.</TD></TR></TABLE>
If he's gonna go with a t3/t4 turbo the 50 trim .48 a/r turbine housing would be much better suited for him.
Old Jul 27, 2008 | 10:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbohatch96y7 &raquo;</TD></TR><TR><TD CLASS="quote">what do you mean with out the turbine housing
and a oil and water cooled turbo is there a big diffrence in cooling</TD></TR></TABLE>
JdmMidWest
19
Feb 12, 2012 10:30 AM
pnk_03
Apr 3, 2008 11:41 PM
EFMAN
Nov 5, 2005 09:25 AM
jbscivichb92
Feb 3, 2005 04:02 PM
Filliam H. Muffman
Oct 3, 2003 02:59 AM
