Is my GM 3 Bar dead?
Old May 6, 2016 | 08:46 PM
evosix's Avatar
Default Is my GM 3 Bar dead?
Just getting around to buttoning up this car before I take it to the dyno. It's your cookie cutter vitara single jingle build.
Car was running fine on stock P28 with stock injectors and stock map sensor.
I put in a xencron basemap to match my setup, 600cc injectors and a GM 3 bar. Car cranks up and runs but not well, if I blip the throttle it stumbles and falls on its face, even cuts off sometimes.
Injectors are firing fine so I tested the GM 3 bar, it's getting a good 5v reference but the output voltage is all over the place so I suspect that this is the problem.
Please look the video below and let me know what you think:
https://www.youtube.com/watch?v=KAlX...ature=youtu.be
Sorry for the sniffling, I have a bad cold.
Old May 7, 2016 | 07:43 AM
TheShodan's Avatar
Moderator
Default Re: Is my GM 3 Bar dead?
Contact Xenocron and ensure that the basemap is specific for a GM 3bar map sensor and not one from another company.
Old May 8, 2016 | 02:08 PM
evosix's Avatar
Does the output voltage really vary from a oem gm 3bar versus aftermarket?
Old May 8, 2016 | 03:10 PM
TheShodan's Avatar
Moderator
Not necessarily the output voltage itself, but the stability and consistency of the village reading on OEM is much nicer from my experience.
Old May 10, 2016 | 08:44 PM
motoxxxman's Avatar
I can't view the video, says it's set to private
Old May 11, 2016 | 06:48 AM
evosix's Avatar
Oops, please try this link:
Old May 11, 2016 | 06:00 PM
motoxxxman's Avatar
what in the hell was that? lol. I've never seen voltage do that before, especially considering it's a 0-5v sensor. I actually didn't expect to see anything like that and don't quite know what to say at the moment. I'll check back if I think of anything
guy_from_nerk
Feb 27, 2012 06:48 PM
h22sedan
Dec 3, 2006 07:46 PM
NA JDM GSR
Oct 29, 2006 08:38 AM
sleeprhatch
Sep 23, 2006 12:04 PM
spidermancivic
Jun 21, 2005 10:25 PM
