My first build!!
Old Apr 18, 2005 | 06:37 AM
  #26
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: (SSBPGSR)
ahhh gotcha
Old Apr 18, 2005 | 06:42 AM
  #27
Quad-Damag's Avatar
Default Re: (boostincoupe)
bling blingg
Old Apr 18, 2005 | 07:12 AM
  #28
SSBPGSR's Avatar
Default Re: (Quad-Damge)
going to the shop right now to put the tranny on, and install the motor. will have vids of the first startup and break in! be back late tonight with updates
Old Apr 18, 2005 | 12:20 PM
  #29
DFW's Avatar
DFW
awaiting updates, GL
Old Apr 18, 2005 | 12:52 PM
  #30
YiNYaNg's Avatar
Default Re: My first build!! (SSBPGSR)
Is that version of block guard good?
Aren't you afraid that the bridges on the block guard might not be strong enough to hold the sleeves from cracking.
Well you get my idea...
Old Apr 18, 2005 | 01:14 PM
  #31
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR &raquo;</TD></TR><TR><TD CLASS="quote">reading is your friend </TD></TR></TABLE>
Are you ditching all of them or just 1 and 2 because of your incorrect assumptions? The 5th gear is still a good idea if it's a daily driver.
Old Apr 18, 2005 | 01:56 PM
  #32
nota-ex's Avatar
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Are you ditching all of them or just 1 and 2 because of your incorrect assumptions? The 5th gear is still a good idea if it's a daily driver.</TD></TR></TABLE>
Same thing I was going to ask. I want to get a GSR with an LS 5th gear. Anyone have an idea as to how much a GSR transmission is, and how much extra it would cost me to have a LS 5th put in it?
Old Apr 18, 2005 | 02:47 PM
  #33
Nytmair's Avatar
waiting for vids/more pics... that's a nice lookin' turbo you got there
Old Apr 18, 2005 | 03:19 PM
  #34
turbodohcsi's Avatar
its an str block guard, same design is also used by golden eagle. if block posting is believed to work then im more then sure this block guard will do its job.
Old Apr 18, 2005 | 04:33 PM
  #35
SSBPGSR's Avatar
Default Re: (turbodohcsi)
yea im just ditching 1 and 2 gear, going to keep the fifth LS. it will do me good on the 700 mile trip i am taking in about 30 days. i forgot my camera today, i put on the all the gears and timing belt. crank pulley, power steering, alternator, painted my distributor. put my IM manifold on and also put the wiring harness back on. im taking it off the engine stand tomarrow and putting the tranny on then installing the motor into the car. LOTS of pics tomarrow, perhaps some video as well. im def filming the first start up which should be tomarrow as well. pray for me everything goes well.
Old Apr 18, 2005 | 04:36 PM
  #36
Ckjeepin's Avatar
This maybe a dumb question,
But arent 2 of the 4 pistons suppose to be up while the other 2 are down..
In the pics they all 4 look even
Old Apr 18, 2005 | 04:40 PM
  #37
SSBPGSR's Avatar
Default Re: (Ckjeepin)
yes they are supposed to be like that at TDC. in that pic i turned the crank like that so they were all even. no question is dumb..everyone has to learn at some point. hope this helped
Old Apr 18, 2005 | 05:03 PM
  #38
Nytmair's Avatar
good luck with the startup, i'll check back for the vid
Old Apr 18, 2005 | 05:49 PM
  #39
Lei Siew Long's Avatar
looks like a promising setup. 400 hp shouldn't be a problem.
Old Apr 18, 2005 | 06:31 PM
  #40
SSBPGSR's Avatar
Default Re: My first build!! (Lei Siew Long)
i sure hope not. might be a while till i get boosted..but the motor is done and will be running tomarrow, check back for vids and pics
Old Apr 18, 2005 | 06:48 PM
  #41
BLANKS143's Avatar
gl with everything!
Old Apr 18, 2005 | 08:41 PM
  #42
integ22's Avatar
Default Re: (BoostedB20Z)
Wow nice build...glad you're getting your setup finished up.
Old Apr 19, 2005 | 05:36 AM
  #43
SSBPGSR's Avatar
Default Re: (integ22)
its 9:30AM, Tue. i am SO damn nervous. after i leave class at 12 i am gunna install the motor with my friend. im not trying to rush anything and im doing the cleanest possible install possible. was anyone else this nervous before they started their brand new motor? so nerve racking
Old Apr 19, 2005 | 06:29 AM
  #44
HondaTechIsTheGay's Avatar
Good luck man.
Old Apr 19, 2005 | 09:53 AM
  #45
turbosi03's Avatar
Default Re: My first build!! (LSVTEC_DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSBPGSR &raquo;</TD></TR><TR><TD CLASS="quote">its 9:30AM, Tue. i am SO damn nervous. after i leave class at 12 i am gunna install the motor with my friend. im not trying to rush anything and im doing the cleanest possible install possible. was anyone else this nervous before they started their brand new motor? so nerve racking </TD></TR></TABLE>
yeah man I was just as nervous when I started mine up, plus I didn't have anyone around that knew anything, plus I invited friends over for add pressure... when I turned the key it started right up but I turned it off because I didn't see oil pressure. turned out I was being a puss and just didn't let it run long enough to build pressure.
looks good man gl
Old Apr 19, 2005 | 10:32 AM
  #46
thehatchninja's Avatar
using my 1000th post to ask
Aren't you worried about 400hp on stock sleeves?
Old Apr 19, 2005 | 11:06 AM
  #47
SPOOLINmatt's Avatar
Default Re: (thehatchninja)
no hes not. neither am i. My friend has been running 447 at 20 psi on a stock sleeve GSR for over a year now. was running 25 psi before that with a shittier tune making 415whp. Im building an LS vtec that will be prolly close to the same, im gonna go a little convservative and stop at about 410whp.
Old Apr 19, 2005 | 11:07 AM
  #48
Default Re: My first build!! (turbosi03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbosi03 &raquo;</TD></TR><TR><TD CLASS="quote">
looks good man gl </TD></TR></TABLE>
Priming the oil pump 0wns you.
Old Apr 19, 2005 | 12:22 PM
  #49
turbosi03's Avatar
Default Re: My first build!! (SP00LIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00LIN &raquo;</TD></TR><TR><TD CLASS="quote">
Priming the oil pump 0wns you. </TD></TR></TABLE>
yeah it did! but I tried to prime it by turning it over without ignition and feed line for turbo in a cup... would not pump, my guess is that my bat was not charged enough to crank the motor over fast enough... so I manually pored oil into the turbo, put the feed back on and started it up...
things to keep in mind
Old Apr 19, 2005 | 01:19 PM
  #50
Default Re: (SP00LIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SP00LIN &raquo;</TD></TR><TR><TD CLASS="quote">no hes not. neither am i. My friend has been running 447 at 20 psi on a stock sleeve GSR for over a year now. was running 25 psi before that with a shittier tune making 415whp. Im building an LS vtec that will be prolly close to the same, im gonna go a little convservative and stop at about 410whp. </TD></TR></TABLE>
that makes me so freakin happy, i was under the impression that you had to sleeve for anything over 300 hp. cool
1002 posts!!!
edit - charlotte.....that's almost SC good luck with your motor.
Modified by thehatchninja at 11:08 PM 4/19/2005
