Are my EGT's high?
Old Mar 7, 2002 | 10:56 AM
  #26
rtype11's Avatar
Default Re: Are my EGT's high? (dustin)
thanks dustin, sorry thought my teg stuff applied - too bad then for prelude owners.
Old Mar 7, 2002 | 10:58 AM
  #27
dustin's Avatar
Default Re: Are my EGT's high? (rtype11)
yeah, preludes suck.
hehehe.
Old Mar 7, 2002 | 02:45 PM
  #28
Quaalude's Avatar
haha rtype11...yup, preludes suck...lol...liam if i richen the mixture, from 10.0:1 to 11.0:1 my car runs like ****...car boggs and hesitates...i have the FJO wideband O2 controller and O2 and it is currently running 11.5:1 from 5500-7500 and runs like a dream...WOT temp now are 900 C with 0 deg/psi on the BTM...cruising temps are 8?? something, i forget...maybe the H22 runs higher temps than the B18 and B16's?
[Modified by Quaalude, 6:47 PM 3/7/2002]
Old Mar 7, 2002 | 02:47 PM
  #29
dustin's Avatar
Default Re: Are my EGT's high? (Quaalude)
I doubt it, 900C is generally known as "Danger area" on all cars....
Maybe your gauge is out of calibration or something? Try using someone elses EGT gauge and probe.
Dustin
Old Mar 7, 2002 | 02:51 PM
  #30
Quaalude's Avatar
yea, maybe...with the above A/F ratios, do u think i am fine?
Old Mar 7, 2002 | 02:53 PM
  #31
dustin's Avatar
A/F ratio looks good...(a little rich)...
If those EGTs are correct though, they are not safe.
Dustin
Old Mar 7, 2002 | 02:55 PM
  #32
Quaalude's Avatar
i have it rich because i don't want to detonate with pump gas and want to be on the safe side...what EGTs are u getting?
Old Mar 7, 2002 | 03:00 PM
  #33
dustin's Avatar
Nothing above 750C, ever. It went down about 70C when I got full 3" exhaust and 3" dp.... Better at evacuating heat I suppose.
Dustin
Old Mar 7, 2002 | 03:05 PM
  #34
Quaalude's Avatar
i still have stock cat. and N1...probably going to get 2.5" testpipe and larger exhaust later
[Modified by Quaalude, 7:05 PM 3/7/2002]
Old Mar 7, 2002 | 04:01 PM
  #35
therealnapster's Avatar
New User
I cant believe your engine didnt melt already, 1000c??? Thats nuts...I dont think preludes would run any hotter than others cause although beefer it still uses the internals are still made of the same stuff. Where is your EGT probe tapped? The closer to your head the hotter the reading, so someone with the guage tapped at the down pipe should have lower temps that some one tapped on the manifold...hope any of this helps.
.ad.
Old Mar 7, 2002 | 04:10 PM
  #36
ElectronVTEC's Avatar
Default Re: Are my EGT's high? (sohckid)
Having too much fuel can push up cylinder pressures and increase EGT's too. Sounds to me like the gauge is whacked because at 1900+F, I'd be freaked and my pistons would be too methinks, heh. EV.
Old Mar 7, 2002 | 04:27 PM
  #37
Xerxes's Avatar
New User
that's what i'm thinking. If he's seeing over 900C there's bound to be something breaking; his car shouldn't be running smoothly..
-Xerxes
d16dcoe45
Nov 9, 2006 08:30 PM
twkdCD595
Aug 7, 2004 12:02 PM
othick
Oct 27, 2003 12:39 PM
BoostedMugen
May 31, 2003 02:28 PM
BorderM3
Dec 30, 2002 11:40 AM
