Is my ecu fried
Old Jan 26, 2005 | 05:00 PM
ebpcivicsi1234's Avatar
Default Is my ecu fried
Well i have been having trouble getting my hondata to read my ecu so i got the chips reburned and same thing led is flashing..So i pluged my stock ecu in and pulled a o2 sensor code,plug in the p28 and get a steady light so 0 which means faulty ecu.I remember when i first got the p28 i hooked it up and turned the key on and it made a funny noise and then i noticed my chip was in backwards....What do you think ???
Old Jan 26, 2005 | 06:05 PM
Default Re: Is my ecu fried (ebpcivicsi1234)
no one has a clue???
Old Jan 26, 2005 | 06:42 PM
xenocron's Avatar
Solid CEL usually means its fried...cut the J1 jumper, take the chip out and turn the key to the 'ON' position, whats happens?
Old Jan 26, 2005 | 06:44 PM
quicksol95's Avatar
Default Re: Is my ecu fried (xenocron)
you could also have a bad chip
had that happen to me
Old Jan 26, 2005 | 08:15 PM
Default Re: Is my ecu fried (slow90hatch)
so i cut j1 jumper...plugeed ecu back in and got a code.So i jumped it and got a code 16 which for obd1 ecu is fuel injectors thats is.So what does this mean i have 550's in there right now is that why its throwing that code?But what is going on with hy hondata and ecu.I have had the chip reburnt already and i had 2 of them burnt so i know it wasnt the chip
Old Jan 27, 2005 | 01:14 AM
BlueShadow's Avatar
So you cut J1 and all you got was a code 16 for the injectors?
Sounds like your ECU is fine. It might be a problem with the soldering )bad connection) or maybe even user error (not burning chip correctly).
Old Jan 27, 2005 | 05:13 AM
Default Re: Is my ecu fried (BlueShadow)
so what do u think i should do send it to hondata and have them re chip it cuz i dont know how to...but should i get that code for my injectors
Old Jan 27, 2005 | 05:46 AM
xenocron's Avatar
I think you should find someone locally that can repair it for you, unless it came that way from Hondata and never worked
Old Jan 27, 2005 | 08:10 AM
no i bought it from phreakmang on h-t funny how whenever hes on he never im's me back on aim but he said it did work......so what should i do and where could i take it
Old Jan 27, 2005 | 08:15 AM
Cray91's Avatar
are you burning the chips??
Old Jan 27, 2005 | 08:24 AM
SOHC_MShue's Avatar
yea your ecu is fine. I had that injector code one time, but one of my injector plugs just came loose. Check your connections.
Old Jan 27, 2005 | 10:07 AM
Default Re: Is my ecu fried (SOHC_MShue)
so ur says my stock p28 with no chip or nothing in it shouldnt throw a injector code cyz i have 550's so ur saying that maybe i have a loose connection and it would just throw the code cuz the 550s...No iam not burning my own chips i had the first one burnt thought that was the problem i had an extra one so i send both to be reburned and have the same problem so i doubt it is the chip being burnt wrong
Old Jan 27, 2005 | 08:15 PM
xenocron's Avatar
Yeah the injector code could just me a loose connector fluke.
As far as your ECU, it could most likely be the latch (HC373) IC
JeffBro
Engine Management and Tuning
11
Jan 5, 2011 04:20 AM
1.8L_allmotormilitia
Jun 4, 2007 08:33 AM
EK k kay
Jul 8, 2006 08:28 PM
ICEMAN707
12
Jul 2, 2006 03:45 PM
