My d16z6b
Old May 20, 2004 | 06:33 PM
Chiovnidca's Avatar
Default My d16z6b
B for boost!!! So far the only problem i've run into is having to notch the bottoms of the cylinders so the eagle rods would clear. (probably cut them a little deeper than needed, didn't want to do it twice.)
And a quick mock-up to position the oil drain hose fitting.
Do you think it will run? Going to have to do without a/c though.
Old May 20, 2004 | 06:54 PM
pip9's Avatar
its not going to run on the stand... install that bitch and see what happens
I had to notch my block too. I notched out more than u and i was ok. You can drop the pistons and rods in and attach them to the crank and spin it over to see if it clears, but u probably already did that to make sure the rods cleared the block
Old May 20, 2004 | 06:58 PM
Chiovnidca's Avatar
Default Re: (pip9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pip9 &raquo;</TD></TR><TR><TD CLASS="quote"> You can drop the pistons and rods in and attach them to the crank and spin it over to see if it clears, but u probably already did that to make sure the rods cleared the block</TD></TR></TABLE>
Yea, I was a little miffed about having to take it back apart. I thought block notching was reserved for stroker cranks. Hope to get it running soon.
Old May 20, 2004 | 07:06 PM
pip9's Avatar
Default Re: (Chiovnidca)
Unfortunally the eagle rods for our motors you need to notch the block out. I've heard that eagle came out with some new rods though for the d-series that you didn't have to but i haven't talked to anyone that has used them.
Old May 20, 2004 | 07:17 PM
Civic_95_Si's Avatar
What kind turbo is that and HP goals?
Old May 20, 2004 | 07:46 PM
z6's Avatar
z6
wat kinda mani is that?
Old May 20, 2004 | 08:42 PM
-16V-'s Avatar
Default Re: (z6)
Look's like a SFP main...?????
Old May 20, 2004 | 09:05 PM
SOHC_MShue's Avatar
Default Re: My d16z6b (Chiovnidca)
looks like a sick setup man
Old May 21, 2004 | 03:22 AM
Chiovnidca's Avatar
Default Re: (Civic_95_Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civic_95_Si &raquo;</TD></TR><TR><TD CLASS="quote">What kind turbo is that and HP goals?</TD></TR></TABLE>
Garret t3-to4e 60/63. Hoping to get 325-350hp before anything breaks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 &raquo;</TD></TR><TR><TD CLASS="quote">wat kinda mani is that?</TD></TR></TABLE>
Got it off ebay. the guy said he makes them at home.
Old May 21, 2004 | 03:51 AM
-16V-'s Avatar
Damn that is a tight *** mani...
Old May 21, 2004 | 03:55 AM
USDM 4G VTEC's Avatar
u need to clear it more
they will touch
i spend 1 hrs making sure they were perfect
and heres my product
for a full size pic heres the link (copy and paste to ur browser since the link "will not" work
copy&gt;&gt;&gt;http://www.imagestation.com/picture/...t;&lt;&lt;this
94c1v1cex
Jan 24, 2008 01:18 PM
MugenB16A2
Mar 28, 2005 12:07 AM
Laney
Sep 15, 2004 04:42 PM
ITSTOCK
Apr 2, 2004 04:45 PM
tygsr
Jun 21, 2002 10:03 AM
