AEM Fuel Rail
Old Oct 19, 2004 | 03:08 PM
S88HON's Avatar
Default AEM Fuel Rail
Any of you guys have any problems using these on FI setup? I bolted on an AEM FPR and the FP was ALL over the place when idle with vacuum off the pressure went off the 100psi gauge! The car was spluttering stalling all the time (haven't even driven it yet!). Replaced with OEM rail with AEM FPR and success! normal idle, no stalling but still missing slightly.. I have an uprated walbro 190l/ph fuel pump running RC310 injectors..
Old Oct 19, 2004 | 03:52 PM
lanojp1's Avatar
Default Re: AEM Fuel Rail (S88HON)
i have one..i think they are all looks...no problems with it yet...
Old Oct 19, 2004 | 03:55 PM
Frozen E's Avatar
H-T White Ops
I have one of the older ones without the extra fitting for a 1/8" gauge or whatever. Been running great on my car for about 4 years now while it was in NA form. Starting tomorrow she'll be seeing boost. Walbro 255 with RC 550 injectors. Gonna see how she does.
Old Oct 19, 2004 | 04:12 PM
Tyler H's Avatar
You didn't happen to install the 1/8 NPT plug and block off the hole to the regulator, did you? I think you did.
Tyler
Old Oct 19, 2004 | 05:47 PM
DaX's Avatar
DaX
Loved
Community Favorite
Tyler H sounds right.
Mine is fine...with an Aeromotive regulator and boost.
Old Oct 20, 2004 | 12:24 AM
S88HON's Avatar
Default Re: AEM Fuel Rail (Tyler H)
Yeah I think I did use that bolt! That was the only one that came with it though! What do you guys recommend?!
Old Oct 20, 2004 | 02:53 AM
S88HON's Avatar
Hi Tyler.
Where am I going wrong? Can you advise me??
Thanks...
Old Oct 20, 2004 | 02:55 AM
Finland's Avatar
I use the rail and regulator, no problems here.
Old Oct 20, 2004 | 09:55 AM
S88HON's Avatar
Default Re: (boost psycho)
Tried it again.. funny fuel pressure OEM rail its fine..
Whats with the NPT thing?
Old Oct 20, 2004 | 10:39 AM
JDMTurboCivic11's Avatar
Default Re: (S88HON)
anyone know what size the fuel line in is? im trying to find a barb since mine didnt come with one.
Old Oct 20, 2004 | 10:54 AM
DaX's Avatar
DaX
Loved
Community Favorite
1/4" ID [or -4AN] I'm fairly certain.
When installing my AEM rail I upgraded to 3/8" [or -6AN] fuel lines in the engine bay.
The AEM rail has an ID of 1/2".
Old Oct 20, 2004 | 10:20 PM
Tyler H's Avatar
You're not supposed to install the plug in the hole behind the regulator. It needs to be open to allow fuel to flow into the regulator and out the return fitting. The hole is tapped in case you want to run a remote mounted fpr. Then you can plug the hole and run a line from the end of your rail into the remotely mounted fpr.
Tyler
Old Oct 21, 2004 | 03:19 PM
S88HON's Avatar
Hi Tyler.. I just inspected the rail again. The hole I plugged up was on the left! I did a quick and simple test. I lit a cigarette and blew smoke down the rail! The unplugged hole (where the FPR was bolted on to) had smoke coming out, So I assume the hole was plugged up right! This is really giving me a headache..
The AEM Rail makes a great bong though
Old Oct 21, 2004 | 03:34 PM
Group Tenacity's Avatar
Tyler's right, you must have had the hole for the fpr plugged...
I never thought of using my fuel rail as a bong tho... i think i'll try that with my old venom fuel rail.. if it works i'll post pics..
Mike...
Old Oct 21, 2004 | 04:25 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: AEM Fuel Rail (Group Tenacity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Group Tenacity &raquo;</TD></TR><TR><TD CLASS="quote">Tyler's right, you must have had the hole for the fpr plugged...
Mike...</TD></TR></TABLE>
Drugs are bad, mkay?
Are you sure the hole on the rail lines up with the hole on the regulator when you bolt them together? If not, this is the problem.
Old Oct 22, 2004 | 12:09 AM
S88HON's Avatar
Default Re: AEM Fuel Rail (DaX)
Yep it sure does! You have 4 holes on the AEM 'logo' bit right? The first hole where the 'A' is plugged up. The second hole is a bolt hole, the third hole is where fuel comes in and the 4th hole is another bolt hole. I assume this is where the FPR sits?
Blew smoke down it and smoke came out of the 'third' hole.
nihad
Jul 11, 2009 08:17 AM
rtpassini
Jan 4, 2005 01:38 PM
BlueTeg
Dec 10, 2004 05:43 AM
BlueTeg
Dec 9, 2004 07:41 AM
VTC_CiViC
Jan 25, 2002 12:41 PM
