My B18B Turbo
Old Dec 20, 2007 | 04:29 PM
lsturbo*'s Avatar
Default My B18B Turbo
....soon to be...
Basically the picts sum it up, I bought 98 B18B with 90K on it and went to town. I have a buddy helping to put the enigne together. I have a 98 GSR shell to put it into and will eventually go turbo. Haven't put much thought into a turbo yet, but aiming for 300-350 HP. I tried to build a stronger engine than necessary for a little safety factor. Only issue so far with the assembly of the engine is the spring install height is off about .025", but we are looking into that. Other concerns of mine are putting the LS engine into a GSR shell, where I would be using the engine's original ECU(98LS). I am hoping it is plug and play.
Old Dec 20, 2007 | 04:33 PM
sctuned.com's Avatar
Banned
Default Re: My B18B Turbo (lsturbo*)
You sure as hell are off to a really good start. When do you plan on putting the motor together?
Old Dec 20, 2007 | 04:40 PM
Schister66's Avatar
Man U FTW
That looks pretty stout for 300-350whp...
Old Dec 20, 2007 | 04:50 PM
lsturbo*'s Avatar
Motor is going together now, I plan to have it in the car by spring when the snow clears up.
Old Dec 20, 2007 | 05:01 PM
SD_Lurker's Avatar
HT White Ops
Default Re: (lsturbo*)
Word around town is you might not want to set your crank laying down like that. Having it standing upright on the flywheel side.
Old Dec 20, 2007 | 05:06 PM
93CX's Avatar
damn, nice stuff 350whp will be just the beginning
Old Dec 20, 2007 | 05:24 PM
lsturbo*'s Avatar
Yeah, just had the crank assy balanced so def. don't want it sitting like that - good catch
Old Mar 3, 2008 | 04:34 PM
lsturbo*'s Avatar
Just an update on my progress...Also, what kind of issues will I run into putting this LS in a GSR? Will driveshafts from the LS work? How about electrical connections, I have the LS ECU to go in this swap. If anyone has done this swap befor can you offer some advice? Thanks
This is the GRS Shell I am putting the LS engine into...and will be turbo someday
Old Mar 3, 2008 | 04:41 PM
quicksilver1689's Avatar
i ♥ snails
with the right turbo you got yourself a stout motor capable of producing some good numbers, that clutch looks a little "whimpy" for the setup.
Good setup non the less.
Old Mar 3, 2008 | 05:11 PM
lsturbo*'s Avatar
yeah, the clutch is a ACT HDSS that can handle 243 ft-lbs. Like I said I really want to be at 300 HP, so I hope this clutch will do it. It is a fine line between a strong enough clutch and too stiff of a pedal. Keep in mind this is a daily driver so I need some sanity.
Old Mar 4, 2008 | 02:00 PM
lsturbo*'s Avatar
Anybody have any advice on my B18B into a GS-R shell swap? I would like to bounce some questions off someone who has already done this swap....
Old Mar 4, 2008 | 04:27 PM
Turbo(less)DB8's Avatar
I haven't done a LS into a GSR but, I've done the other way around. I used my stock LS axles and everything when fine. Both the engine and the car were 99s. I did run into one small issue electrically and that was that the tdc (forgive if I get the name wrong. It was 2yrs ago.) was in the wrong plug at the shock tower. I'm assuming this will be the same for you. I hope this helps.
Ryan
Old Mar 5, 2008 | 04:20 PM
paton5g's Avatar
Default Re: (Turbo(less)DB8)
everything in the build looks great. i just bought a 96 RS today and looking at these pics is making me very jealous. i wanted to do a b20 turbo, but now i'm thinking about another b18b and just boaring it. what CR are those pistons?
Old Mar 5, 2008 | 05:20 PM
lsturbo*'s Avatar
Default Re: (paton5g)
I thought there were a direct replacement of 9.1, but looking at the paperwork, they are 9.35 so just a hair over stock. I went with 83mm in case I ever need to clean it up in the future. I have heard the sleeves can go to 85mm max.
Old Mar 5, 2008 | 05:23 PM
lsturbo*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo(less)DB8 &raquo;</TD></TR><TR><TD CLASS="quote">I haven't done a LS into a GSR but, I've done the other way around. I used my stock LS axles and everything when fine. Both the engine and the car were 99s. I did run into one small issue electrically and that was that the tdc (forgive if I get the name wrong. It was 2yrs ago.) was in the wrong plug at the shock tower. I'm assuming this will be the same for you. I hope this helps.
Ryan</TD></TR></TABLE>
thanks for the info, but could you explain the TDC sensor problem a little more? I assume you are talking about the crank sensor mounted under the timing belt cover?
Old Mar 15, 2008 | 01:52 PM
paton5g's Avatar
was that a block guard i saw in those first pictures? where did you pick that up? is that an alternative to having stronger sleeves put in, or would you still run one with new sleeves?
Old Mar 15, 2008 | 03:01 PM
RCautoworks's Avatar
Nice little build coming along there
Old Mar 16, 2008 | 04:52 PM
lsturbo*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paton5g &raquo;</TD></TR><TR><TD CLASS="quote">was that a block guard i saw in those first pictures? where did you pick that up? is that an alternative to having stronger sleeves put in, or would you still run one with new sleeves?</TD></TR></TABLE>
No block guard, that piece you see was installed from GE when the sleevd the block.
cracker1252
Dec 11, 2006 10:55 PM
Jwbetley
Dec 8, 2004 09:47 AM
92accordex
Jul 23, 2003 06:58 AM
EK9_18PSI
Apr 27, 2002 08:24 PM
