MSD settings for a BTM
Old Aug 11, 2002 | 09:14 AM
bottlefedb18c1's Avatar
Default MSD settings for a BTM
i have a b18c1 with a drag gen 3 kit with 310cc injectors running 6-9 psi of boost how much ignition retard should i be running with the colder 7 series plugs from ngk and how much should it be if i had stock heat plugs? i am useing .5 of a degree with the colder ones is that to much or to little?
Old Aug 11, 2002 | 05:35 PM
Default Re: MSD settings for a BTM (turbogsrb18c1)
is there anyone that is using a BTM on there FI Honda/Acura?
Old Aug 11, 2002 | 05:38 PM
redline's Avatar
1/2 degree per pound 16 degrees base timing.
Old Aug 11, 2002 | 05:40 PM
JM Performance's Avatar
Default Re: MSD settings for a BTM (redline)
i'm using .25 for street and 0 for track. thats w/ 9psi on an LS...i wouldn't try that w/ a gsr though..
Old Aug 11, 2002 | 06:07 PM
Default Re: MSD settings for a BTM (00SilverLS)
i am at 16 deg with .5 per psi with the 7 series ngk plug
Old Aug 11, 2002 | 06:32 PM
another thing when i was on they dyno, butting the btm to 1deg took almost 20 hp out.
Old Aug 11, 2002 | 06:44 PM
CovertFI's Avatar
i dont know if you can use it on anything else because it is boost dependent.
Old Aug 11, 2002 | 07:55 PM
i have felt the power drop to at 1 deg i went down to .5 but dont know if i should go farther i might with the colder plugs
Old Aug 12, 2002 | 06:52 PM
rice4life's Avatar
is that 20hp drop from 0 deg to 1 deg/lb or what. wow, you run 0 deg at 9psi at track.
Old Aug 12, 2002 | 06:53 PM
rice4life's Avatar
i have mine at .75 deg/lb with stock timing at idle. also using ngk 7 heat range.
Old Aug 12, 2002 | 07:26 PM
Default Re: MSD settings for a BTM (rice4life)
i am running stock timming and .5 per psi on the btm is that too much or can i go lowwer? i also have ngk 7 heat plug
Boostinb20!
Jul 16, 2009 02:33 PM
Boostless97Lude
Feb 22, 2003 01:35 PM
BLKCRX
Jan 15, 2003 07:51 PM
SIK IN DA HED
Aug 13, 2002 02:43 PM
Sh4rky
Apr 2, 2002 01:34 AM
