Msd dig6+ install questions?
Old Apr 26, 2002 | 05:28 AM
PM-Performance's Avatar
Default Msd dig6+ install questions?
well i got everything almost done , bu msd gives some cheesey schematics, im stuck at how to wire this thing with the external coil
i have the external coil hooked up with the black and orange, and then running the white into the cap to go to where the negative of the stock coil went , im assuming into the amplifer module or whatever? anyway where the does positive wire from the stock coil go? does that get connected anywhere?
it is connected to the amplfier also , but has a bridge off it where it connected to the coil, and now just not being used.
i just taped that up last night and tried to start it and it wouldnt start, it blew the coil fuse. so i put it back to stock until i get some better instructions . any help would be appreciated, i have a big race this weekend and nede to get this figured out, thanks guys
Old Apr 26, 2002 | 05:56 AM
D-Man's Avatar
Default Re: Msd dig6+ install questions? (itr206)
im not sure of the color codes on a itr distributor but on my EF,the Red MSD runs to the Black/yellow stripe and the White MSD runs to the Yellow/Green stripe.....the blk/yellow and the yellow/green use to connected to the coil inside the dist.
Old Apr 26, 2002 | 06:14 AM
Default Re: Msd dig6+ install questions? (D-Man)
so i have to run 2 wires into the dist cap?
i have a wire for +, for ground , 2 wires for my external coil. one for the 2 step, 1 for the retard for nitrous, and one for the - where the coil used to be ? and switched 12v going to the igniton swx?
im stumped .
Old Apr 26, 2002 | 06:22 AM
ok i called msd and they said i need to run the blk/yellow wire to the switched 12v and thats what starts the car. . .oops. that was the part that got me . the directiosn are pretty confusing .
Old Apr 26, 2002 | 06:29 AM
D-Man's Avatar
yeah,those msd directions are a little confusing,i believe they have a couple of diff diagrams for honda/acura's
Old Apr 26, 2002 | 07:22 AM
nope , they are all for freaken domestics.
Old Apr 26, 2002 | 09:47 AM
dariusz's Avatar
Exactly
smash fascism
Jul 4, 2005 10:01 PM
deftones0817
Jun 20, 2005 06:59 AM
JDMs1eeper
Dec 2, 2003 07:50 PM
B_1_8_hatch
Nov 28, 2003 08:28 PM
jdm_ef9
Feb 24, 2002 09:57 PM
