msd btm ignition question
Old Sep 20, 2001 | 06:30 PM
not so civic's Avatar
From: gravity rides everything...everything will fall, se GA/ne FL
Default msd btm ignition question
i have a friend who wants to trade me the msd btm for my turbo timer and a gauge. the deal is good i guess, but if it is not going to do me much good then i am not going to do this trade. i am boosting 10 psi on an ls in a hatchback. i guess the stock ignition is doing ok...should i upgrade and what difference will it make performance wise? because i just can't see an ignition making any power gains, but i am sure it helps at some boost levels.
Old Sep 20, 2001 | 06:36 PM
JM Performance's Avatar
Default Re: msd btm ignition question (ho focker)
Whats your timing set at now? Whats good about the BTM is it lets you keep your stock timing when your not in boost and better timeing in low boost, but still retard it in high boost so you don't have detonation. It'll probably add low and midrange power.
Tad
Dec 17, 2003 03:10 PM
CalvitoSol
Jul 3, 2002 02:28 AM
b18tdelsol
May 1, 2002 11:25 PM
ndmracing
Jul 17, 2001 09:39 PM
