MSD BTM
Old Aug 25, 2003 | 04:09 PM
SOFLSOL's Avatar
Default MSD BTM
Anyone got the instructions for the btm install on a y7 its part number 5462. I got the ones from the jackson racing install for the EF's. But not sure how that relates to newer systems.
Old Aug 26, 2003 | 11:30 AM
scttydb411's Avatar
Default Re: MSD BTM (SOFLSOL)
orange to neg side of coil
red to pos side of coil
white to trigger-wire that was on neg side of coil originally
black to ground
timing **** connectors are obvious connection
boost vac line to brass nipple on side of btm.
Old Aug 26, 2003 | 01:01 PM
CivicSoul's Avatar
Default Re: MSD BTM (scttydb411)
I am glad it is that easy, unfortunatly, I am stuck on a good way to mount the wires threw the distributer. There is no obvious place to drill the distributer, and the "threw the cap" design requires modification every time you change your cap. I would love to see a pic of an install!
Old Aug 26, 2003 | 01:19 PM
scttydb411's Avatar
Default Re: MSD BTM (CivicSoul)
i just drilled a hole on the bottom side of the cap...don't see the wires going in and if it were to get moisture it would be able to drain out. you will have to modify the cap some way.
Junaid K
Mar 22, 2014 10:26 PM
jazmie
Apr 1, 2010 01:14 PM
warchieft2k
Nov 24, 2006 05:03 PM
sleeprhatch
Jun 3, 2005 11:10 AM
jdm_ef9
Feb 24, 2002 09:57 PM
