MSD Dizzy Cap.
Old Mar 19, 2014 | 01:03 PM
Junaid K's Avatar
Post MSD Dizzy Cap.
Hey guys,
I have been toying with the notion of an external coil for a while now, especially for when I go boost, so when these items came up, from a friend, I grabbed them.
How do I hook this up? I'm using a stock dizzy and this msd cap. What am I missing? He did mention an ignition driver 6305, but is that necessary? What if I used a different coil, like say a Bosch coil?
Thanks
Old Mar 21, 2014 | 08:05 AM
F22Master's Avatar
Default Re: MSD Dizzy Cap.
Not 100% sure on the exact install procedures, but this is the basic idea:
Remove stock coil from dizzy
Cut the coil wires and splice in extensions (long enough to reach the external coil)
Run the new extended wires to the external coil (they go on the 2 brass screw terminals)
Install the MSD cap
Run the red wire (with the gray ends) from the external coil, to the top lug on the msd cap
Old Mar 21, 2014 | 03:44 PM
Junaid K's Avatar
Install the MSD cap
Seems simple enough, but will I need that ignition driver? Probably on this coil, but as I suggested, how about a different coil?
Old Mar 22, 2014 | 10:50 AM
F22Master's Avatar
Not sure. My setup didnt have anything but the cap, external coil, and two extended wires...But I have the red coil, not sure if it's the same or not.
Old Mar 22, 2014 | 10:26 PM
Junaid K's Avatar
OK, so it seems that it's possible to use an alternate external cool then.
Anybody knows the benefit in using this coil with the additional (expensive) ignition driver, vs a regular external coil like a Bosch coil?
honda_SiRII94
Apr 9, 2007 08:14 AM
SpoolnByYou
Mar 25, 2006 09:10 AM
xci_ed6
Oct 14, 2003 08:42 AM
jdm_ef9
Feb 24, 2002 09:57 PM
