msd
Old Sep 24, 2008 | 04:42 PM
blueintegra's Avatar
Default msd
hey HT I installed a msd 6al with 2-step in my integra gsr and it has a 4000k pills and a 9000k pills. For some reason car wont rev pass 7k and my ecu was set at 8500
Old Sep 24, 2008 | 05:03 PM
LSTEG96's Avatar
Default Re: msd (blueintegra)
sounds to me like your muffler bearings are going out.
Get more specific. Stock ECU? stock gsr? "set at 8500" by what?
Old Sep 24, 2008 | 05:58 PM
Default Re: msd (LSTEG96)
turbo gsr running hondata. was running fine b4 installing msd 6al with 2 step
Old Sep 24, 2008 | 06:25 PM
JSPECSIR's Avatar
the new 6al or the old one? also did it have the wires to cut for 4,6,8 cylinder? if so did you cut them?
Old Sep 24, 2008 | 06:29 PM
Default Re: msd (JSPECSIR)
the old one i havent cut it i got it from a friend who had it on a integra
Old Sep 25, 2008 | 03:19 AM
boostedcivicsir's Avatar
Mr. Badwrench
undo the 2 step, take the pills out and see what happens.
Old Sep 25, 2008 | 07:26 AM
JSPECSIR's Avatar
Default Re: msd (boostedcivicsir)
check to make sure the 4 cyl loop is cut and ^^like he said take the pills out. that will eliminate its rev limit and use your computers limit. those pills have resistors inside of them and they are subject to change slightly with temperature. you can contact msd tech support and they can tell you what they should read with a meter.
i did notice on my old setup, it seemed as if the longer the wires were connecting all the compoents the further my tach seemed off.
Old Sep 30, 2008 | 04:48 PM
i check its cut already. today i tried taking off the pills and it work normal. wats going on ?
Old Sep 30, 2008 | 06:55 PM
JSPECSIR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECSIR &raquo;</TD></TR><TR><TD CLASS="quote"> those pills have resistors inside of them and they are subject to change slightly with temperature. you can contact msd tech support and they can tell you what they should read with a meter.</TD></TR></TABLE>
90tegboosted
Engine Management and Tuning
May 24, 2013 04:31 PM
blueintegra
Sep 25, 2008 04:07 AM
IntegR
Dec 19, 2006 05:24 PM
hybridEj6
Mar 21, 2003 07:44 AM
Hard2Find
Jun 18, 2002 04:55 AM
