Motorswap vs. motorbuild for INTEGRA TURBO???
Guest
Posts: n/a
Hey guys,
i have a 1995 integra LS with a t3/t4 turbo.
I've noticed that the rings are leaking and i'm getting a shitload of blow by. I'm thinking if i should go with a DC GS-R (B18c1) motor or just rebuild the LS...i have about $5500 to play with. Any suggestions? TIA.
Re: Motorswap vs. motorbuild for INTEGRA TURBO??? (troublecodes)
I would rebuild the B18B motor. You'll be great for the long run if you sleeve and fully build the motor. If you get a B18C it'll just be a matter of time til the rings landings crack. Plus, you never know what the condition of the motor is in when you buy a used mootor. You might end up needing to rebuild that then and it might be over your budget.
I agree, rebuild the motor you have. You never know what you are getting when you buy a used motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by troublecodes »</TD></TR><TR><TD CLASS="quote">kno anywhere i can get buildup suggestions?</TD></TR></TABLE>
I would search around here and look over other people's setups. That's the best way to get ideas.
i would go with earl
Guest
Posts: n/a
Re: Motorswap vs. motorbuild for INTEGRA TURBO??? (redturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redturbocivic »</TD></TR><TR><TD CLASS="quote">
i would go with earl</TD></TR></TABLE>
the mod?
the mod?
the mod?</TD></TR></TABLE>
yea
yea
Re: Motorswap vs. motorbuild for INTEGRA TURBO??? (envision2teg)
You'd end up waaaaaay better off by race building that B18b for the same cost of the stock B18C1 which'll just blow eventually.
send the block to earl and get benson sleeves and do a ls/vtec turbo, i totaly agree y get somthing that is used u never know the real reson y someone sold it. plus you already know whats up with your motor
Here are two threads on the Benson blocks he sells:
Benson Sleeved Blocks..How they are made and why they are the best https://honda-tech.com/zerothread?id=565375
https://honda-tech.com/zerothread?id=692320
billyinse
35
01-20-2007 11:46 AM
