Motorola 2.5 bar map?
When running the motorola 2.5 bar map, do you people still connect the stock map sensor to its connector clip? Or just unplug the connector from the clip from the stock map sensor and just run the motorola 2.5 bar map alone? Going to install it soon so any help I will appreicate it.
u only plug the Motorola map sensor in. just leave to stock plug hang their, so if u ever need to use a stock map sensor all u have to do is plug it in
Yup, I agree. Don't cut the stock plug off, tee into the wiring or put the pins into a spare 4P connector and keep the stock MAP sensor plug handy for if you ever go back stock.
