Motor is using water
Old Aug 8, 2009 | 02:29 PM
  #26
boosted91crx's Avatar
Default Re: Motor is using water
smokes pretty good down the track.
Old Aug 8, 2009 | 02:30 PM
  #27
cfwthb_94's Avatar
Here are some pics of the head gasket still on the block
Old Aug 16, 2009 | 02:04 PM
  #28
cfwthb_94's Avatar
a little update: I got my head back from the machine shop and everything checked out perfect on the head. But he did notice, what appears to be the piston hitting the head:
I wasn't able to check the block with a bridge and dial. I used a straight edge though, which ended up being more of a pain in the *** than anything. I bought a cometic .051 84mm headgasket to give some clearance.
I have a question... Could I trim out the chamber on the cylinder head to match up to the 84mm bore of the block? Would that help at all? thanks
Old Aug 18, 2009 | 07:06 AM
  #29
Cyphear's Avatar
Are there copper rings at the top of your sleeves? I think I remember my GE sleeved block coming with small copper "o-rings" around the sleeves. You should check and see if you have those (or if you're supposed to have them) and if they are in good shape.
Old Aug 18, 2009 | 07:13 AM
  #30
cfwthb_94's Avatar
no copper rings. That's an option though, but this block doesn't have them.
Old Aug 18, 2009 | 10:09 PM
  #31
Turbo_TONY's Avatar
what does the guy say halfway down the track? i couldnt make it out.
Old Aug 19, 2009 | 07:45 AM
  #32
cfwthb_94's Avatar
He's saying Come on baby, POP, Come on...Damn it....what a way to....?
My gf said that after my run he said he was taking bets on when my car was going to blow up. F*&k D*$k
Old Aug 19, 2009 | 09:24 AM
  #33
Cyphear's Avatar
That's what mine looked like on the run where I had cracked a sleeve. It went up in smoke at the end of the track when my radiator hose poped off.
tehtyler
May 28, 2012 06:19 PM
ej1916
13
Jan 5, 2011 10:39 AM
ATgrills.com
Honda S2000
39
Apr 19, 2008 11:53 PM
efrex
May 22, 2007 03:23 PM
