Motor problems
Old Dec 29, 2001 | 05:51 AM
hybrid901's Avatar
Default Motor problems
I spent all night swapping blocks in my car. I bought the b18c1 block used with srp 9:5:1, eagles, and block guard. After we get it all in I have 1 problem. When we spray carb cleaner on the front passanger side on the block its sucking in into the combustion chamber and almost dying. Could the block be warped that bad? I'm using arp head studs, should I tighten them more that 82ft/lbs with oil? What else could be my problem. Its also is going threw water like a blow head gasket but the gasket is brand new. Please any help. I'm gonna go sleep for 3-4 hours and go tear it down.
Old Dec 29, 2001 | 09:54 AM
hybrid901's Avatar
Default Re: Motor problems (hybrid901)
anyone?
Old Dec 29, 2001 | 10:20 AM
immortal's Avatar
Banned
you wonder why he sold the block now dont ya......
Old Dec 29, 2001 | 10:28 AM
hybrid901's Avatar
Default Re: Motor problems (immortal)
has anyone ever had this problem using arp head studs?
Old Dec 29, 2001 | 10:48 AM
dustin's Avatar
You sure you installed the head gasket the right way?
Old Dec 29, 2001 | 02:38 PM
MackSpeed-616's Avatar
we have had this problem many times with studs. give it a shot with honda bolts and honda gasket. never go beyond factory tq specs.
Old Dec 29, 2001 | 03:39 PM
hybrid901's Avatar
Was I not susposed to tightnen the stud past the factory tq spec. Does anyone know off hand what the factory tq spec is?
Thanks
Old Dec 29, 2001 | 03:41 PM
Aahj's Avatar
you should invest in a Helm's manual
Old Dec 29, 2001 | 05:05 PM
hybrid901's Avatar
Default Re: Motor problems (ajn)
I have 1 but I let my buddy borrow it for putting his block together and I figured someone on here would know it off hand. Thanks for your help.
Old Dec 29, 2001 | 05:35 PM
FBP Ex-T's Avatar
damn i should get one too.since im installing myself...and another good point not to torque more than fac. specs...damn i think my install is gonna go perfect! keep bringing the info....
did u check the cylinder walls and everything before the install???
Old Dec 29, 2001 | 05:55 PM
sgT's Avatar
sgT
60lbft
remember, start in the middle and work outward
michaellong
Jul 30, 2018 07:37 AM
EG-SIXV-TEC
15
Sep 9, 2013 08:57 AM
MR.johnson
Jun 15, 2012 07:48 AM
ATS*Mark
Mar 8, 2004 06:39 AM
servion
Jun 13, 2003 09:07 AM
