moroso 5.5 qt oil pan???
Tried to do some searching but I havent got a definate answer. I have a moroso pan with the kicked out sump. The person I bought it from said that my stock LS pick up will do fine with it but I was wondering if it was neccessary to buy the aftermarket pickup from moroso? Thanks
Re: moroso 5.5 qt oil pan???
Awesome i guess i was just a bit paranoid. Will the stock dip stick also function accurately? Are you guys putting exactly 5 qts oil into the engine or 5.5?
i use the stock pickup with my moroso too no problems just run the stock one and save money unless your pickup is bad then switch it out. and on my set up i use a stock dip stick and have no problems cant answer the fill question due to having a filter relocater and cooler
For some reason I thought you need to run their pickup with their Aluminum pan but not with the steel pan, I cant remember though....... why would they sell it if you dont need it at all?
I run the steel pan with a stock pickup.
summit still has the pans if moroso has them in the warehouse they will still sell them and if your going to get one get the steel one the aluminum ones leak like crazy if they hit anything or not tightened perfectly
