More Probs
Old Jan 27, 2002 | 02:19 PM
1.8EG-T's Avatar
Default More Probs
Today, I started up my car to get the code 22, vtec pressure sensor, do these things just go bad, because it is plugged in or is this a symptom of oil pump failure.
Setup is a drag turbo, with lsvtec, the sensor on the back of the block is tapped twice, coud this be it. I never had a problem with it until today.
Old Jan 27, 2002 | 02:51 PM
boost killz's Avatar
New User
Default Re: More Probs (hybridrex)
I had the same code a few months back, making me change the vtec spool valve filter, o-ring on top of solenoid, and resetted the ecu which cleared it for a week then slowly returned to haunt me. In the end it was the sensor itself. also once the code appeared it would cause the car to bog like crazy at vtec engagement. Bought the new sensor(green piece) that goes in the vtec housing reset the ecu and never had the problem again. sensor was about 55 bucks for a POS as big as your thumb. But then again my setup is a gsr engine. Good luck man!
BTw if acura doesn;t have the sensor the SI's use the same poo poo and you can purchase from a standard honda dealer.
Nick
Old Jan 27, 2002 | 02:57 PM
1.8EG-T's Avatar
Default Re: More Probs (boost killz)
Thanks.
ntoxicatedtigah
Jun 24, 2009 02:56 PM
1clean_ Ej
Feb 28, 2007 08:07 PM
mikebranson
Apr 13, 2004 09:00 PM
hondacrx90
Apr 3, 2004 10:01 AM
psycho_civic
Oct 23, 2003 08:33 AM
