Golden Eagle Mfg. Article
Old Dec 28, 2001 | 01:58 PM
Armaan's Avatar
Default Golden Eagle Mfg. Article
http://www.overboost.com/story.asp?id=464
Old Dec 28, 2001 | 02:07 PM
D-SPEED's Avatar
Default Re: Golden Eagle Mfg. Article (2.0L Turbo)
Old Dec 28, 2001 | 03:04 PM
Bnjmn's Avatar
A side note- the GE group buy is still going- I need two more people, check the webpage below- http://home.rochester.rr.com/bplesn/goldeneagle.html
Thanks
Ben
Old Dec 28, 2001 | 03:22 PM
b18bvudoo's Avatar
New User
Default Re: Golden Eagle Mfg. Article (Bnjmn)
i would join this groupbuy if i had a b20 block, but i dont
Old Dec 31, 2001 | 10:40 AM
Armaan's Avatar
Default Re: Golden Eagle Mfg. Article (vudoo666)
You don't need a B20 block
Old Dec 31, 2001 | 10:42 AM
VaporTrail's Avatar
New User
you can have your LS resleeved to 84 or even 85 mm, which makes it exactly the same as a B20 block but stronger I had my GSR block sleeved to 84.5mm by them, it came out purty
Old Dec 31, 2001 | 10:28 PM
b18bvudoo's Avatar
New User
i know, but thats the blocked i'd want sleeved to 84.5
Old Dec 31, 2001 | 10:58 PM
Arturbo's Avatar
Better than steak
25 Year Member
Thanks
Ben
Ben, On the Endyn board Vince said the group buy was over. So Im assuming its on again?
art
Old Jan 1, 2002 | 02:29 AM
SC Si's Avatar
What is the max you can bore out a B16? Is it possible to bore it out to 85mm.
Thanks in advance
[Modified by SC Si, 11:30 AM 1/1/2002]
Old Jan 1, 2002 | 10:40 AM
VaporTrail's Avatar
New User
Default Re: Golden Eagle Mfg. Article (SC Si)
Thanks in advance
yes, you can safely bore a f/i B16a block to 85mm.
Old Jan 1, 2002 | 12:29 PM
Bnjmn's Avatar
Default Re: Golden Eagle Mfg. Article (Arturbo)
An individual involved in the group buy was ripped off when buying a block, so a couple slots opened up.
Thanks
Ben
Old Jan 1, 2002 | 05:08 PM
Simon_the_Pieman's Avatar
Default Re: Golden Eagle Mfg. Article (VaporTrail)
if you can bore your 1.8 block to 2.0 safely, what can you bore your 2.0 block out to? or is that just unsafe?
Old Jan 1, 2002 | 05:59 PM
InfamousRS's Avatar
Default Re: Golden Eagle Mfg. Article (Simon_the_Pieman)
the b18a/b and b20 blocks are exaectley the same, the only difference is the bore on the b20 is 84mm, and the b18 is 81mm. For a boost application, the largest I have heard is safe is 84.5mm. Endyn makes a piston this is perfectect for that setup.
Old Jan 27, 2002 | 02:15 PM
Brian_92GSR's Avatar
New User
Default Re: Golden Eagle Mfg. Article (BLK94RS)
Would a b17a block be safe to bore to 84.5mm when getting resleeved by g.e.? Any advice on pistons or rods to get when boring the b17 to 84.5 - this is for forced induction.
Old Jan 27, 2002 | 03:04 PM
The Punisher's Avatar
Default Re: Golden Eagle Mfg. Article (Brian_92GSR)
I was just about to hit you with an email. Yes, you can bore to a 84.5 mm safely. I would suggest the Eagle rods and Endyn pistons, but I am checking on the Arias pistons for you.
