More Precision questions
Old Nov 4, 2003 | 09:41 AM
raene's Avatar
Default More Precision questions
I'm curious about the bolt patterns and sizes of the Precision series of turbos. I assume they're all roughly similar but I'm particularly curious about the SC50. I'd like to pick up a cheaper model of turbo as a stopgap until I can afford the SC50.
Since it's a Garrett series, am I restricted to Garrett turbos? Which turbos in particular share sizes with the SC50 and Precision SC series and are swappable? Thanks H-T Gotta get this turbo setup off the ground before next season begins but student loan repayments + moving out is killing me...
Old Nov 4, 2003 | 12:03 PM
raene's Avatar
Default Re: More Precision questions (raene)
Bump... specifically, are the Precision housings 4 or 5 bolt?
I see the site says 5 but I've seen on H-T that they can be had in 4-bolt style...
Old Nov 4, 2003 | 12:13 PM
kpt4321's Avatar
They are the standard Garrett T3 outlets, which can be had in 4 bolt or 5 bolt, I believe.
If I'm right, then the 5-bolt flows more.
Old Nov 4, 2003 | 12:22 PM
raene's Avatar
Default Re: (kpt4321)
Thank you
Old Nov 4, 2003 | 12:34 PM
EG6owner-T's Avatar
Default Re: (raene)
i have the sc-50 its like any other t3/to4e... let me know if you want more...
it works great with ls motor, with the .48 a/r boost kicks in earlier and harder... i got the 5 bolt for the dp
Casey
Nov 7, 2011 07:35 PM
GroundZer0 336
Oct 1, 2006 09:03 AM
StreetEG
Jul 27, 2006 06:21 PM
1.8T_EG
Mar 13, 2004 02:46 PM
