Is this a mistake or for a reason? (prelude engine question)
Old Jun 12, 2002 | 10:38 AM
2000Accord5sp's Avatar
Default Is this a mistake or for a reason? (prelude engine question)
Just because you guys prob build engines up a lot, I wanted to ask your opinions. I've taken apart my engine a long time ago so I don't remember but I was going to order new rod bearings. I would assume there's 8 all together. 2 per rod. But if you look at this link, there's only 7. Why would one rod only have one bearing??? I'm confused...
The Rod bearings are #23 in the table. You'll notice each one has it's own color but there's only 7 of them...
http://www.hondaautomotiveparts.com/...NKSHAFT-PISTON
Old Jun 12, 2002 | 10:54 AM
PrecisionH23a's Avatar
Default Re: Is this a mistake or for a reason? (2000Accord5sp)
there should be 8 total, 2 per rod (top and bottom halves).
Old Jun 12, 2002 | 11:23 AM
dustin's Avatar
Bearing color = bearing size. You select bearings that match the rod bore and crank journal sizes. It's not like there is a part number for cylinder 3 upper rod bearing because all rods and cranks are different.
dbb95ex
Aug 12, 2009 09:07 AM
boosted crx-r
Mar 25, 2007 07:12 AM
H22Luda720
Apr 5, 2006 05:27 PM
Brian_92GSR
Apr 2, 2002 01:53 PM
CivicNewbie
Jan 24, 2002 10:42 AM
