misc info...
Old Aug 22, 2002 | 03:47 PM
zcivic91's Avatar
Default misc info...
hey where can i get those .5" plates so i can make an adapter for my homemade turbo??
also ill be running 6 psi nonintercooled...and i drive on i95 alot for like an hour..my rpms usually stay at 3800 rpm...is this going to be hard on the motor..being ill be goin down the road at 6psi..
also should i get an fmu wit my 290cc injectors that i have...and if so wat size??
[Modified by zcivic91, 3:22 PM 8/23/2002]
Old Aug 22, 2002 | 05:13 PM
zcivic91's Avatar
Default Re: misc info... (zcivic91)
Old Aug 22, 2002 | 06:34 PM
Farnsrocket's Avatar
If I knew what you were trying to say, I would try to help.
Old Aug 23, 2002 | 06:22 AM
zcivic91's Avatar
Default Re: misc info... (Farnsrocket)
ok now u can read it..
Old Aug 23, 2002 | 08:00 AM
00civicvtec's Avatar
Just don't use an aluminum adapter plate...there's a few people who make them for a little under $100, otherwise you will have to get your machine shop to fab one up.
Also, you won't be boosting when your engine isn't under a load (ie WOT), that's a common myth, so no worries there.
I personally hate FMUs because of their semi-harsh transition into boost, having to use check valves, pushing crazy fuel pressure, and you can't tune it, but if you use one, make sure you upgrade your fuel pump (Walbro 255lph HP).
I'm personally going AFC+450cc injectors myself, much better setup, I can tune it with a wideband, don't have to use check valves, and keep stock fuel pressure.
Old Aug 23, 2002 | 08:41 AM
zcivic91's Avatar
Default Re: misc info... (00civicvtec)
well i already got my 290cc and i cant find the 450's so i guees ill do it this way...besides ill never up the boost..fear..
i can get an adjustable fmu...wat should i start it at?? 10:1
aslo wat do u mean by harsh transititon??
i got an inline pump...
i still need to konw where i could get a steel plate from....the home depot is 30 min away i dont wanna waste time finding out they dont carry sumtin like that..
Old Aug 23, 2002 | 09:15 AM
You can get 450's at any junkyard, partstrader, ebay, everywhere for no more than $50.
Don't know about FMU settings, like I said I don't like FMUs
Home depot doesn't have any, If I were you I'd buy one pre-fab'd, because it will end up costing the same or more if you buy the block and have it machined.
Old Aug 23, 2002 | 10:18 AM
QuickHonda's Avatar
Heres the plate. Their site also has tons of info on piecing together a junk yard turbo kit. I've personally met these guys and their very cool and honest.
http://www.gamesbbs.com/~turbosi/adapter.html
Old Aug 23, 2002 | 10:38 AM
zcivic91's Avatar
Default Re: misc info... (QuickHonda)
i have a toe04h mitsu turbo..so that plate wont work..
and besides im doin it wit the a/c so i actually need 2 .25" plates and a 3" exhaust tube welded..but i can make the plates myself then have the tube welded onto the exact location it needs to be.
where do i need to goto to get a dam steel plate??
also wat about my fmu wat size do i need?
Old Aug 23, 2002 | 03:22 PM
zcivic91's Avatar
hmmm..
grover
Sep 27, 2004 03:17 PM
arjusmc
Sep 27, 2002 05:25 AM
ATgrills.com
Sep 18, 2002 08:02 PM
TurboSi
Mar 28, 2002 10:25 AM
ludelvr
Dec 19, 2001 07:50 AM
