Minimum Distance Between cylinders...
Old Mar 9, 2004 | 02:50 PM
qksl2's Avatar
Default Minimum Distance Between cylinders...
On a GE sleeved motor, what do you consider is the minimal amount of distance required between each cylinder to prevent head gasket problems? B18b
Thanks.
Old Mar 9, 2004 | 03:19 PM
Vadian's Avatar
Default Re: Minimum Distance Between cylinders... (qksl2)
Or in other words, how big can you bore your sleeves right?
I'm at 85.5mm right now and its pretty darn thin.
Old Mar 9, 2004 | 04:43 PM
95LSDOHC's Avatar
Default Re: Minimum Distance Between cylinders... (Vadian)
good Q...bump
Old Mar 9, 2004 | 06:08 PM
RenoRacing's Avatar
Default Re: Minimum Distance Between cylinders... (95LSDOHC)
86mm has been done on b series and several that see daily driving and/or boost. 87mm is golden eagles race worthy beasts but they recommend no bigger than 85mm for street cars and the weak at heart.
Blammo
Aug 30, 2007 08:11 AM
JoeDaSoto
Jan 8, 2007 05:29 PM
sheepey
Oct 10, 2005 03:58 PM
Turbocivic94
Apr 25, 2005 06:21 PM
thor559
Sep 9, 2003 09:43 PM
