milling head or high compresison pistons?
Old Jul 21, 2003 | 02:58 PM
liam821's Avatar
25 Year Member
Default milling head or high compresison pistons?
have a question. Im currently building a honda DOHC ZC turbo motor.
(75.5mm bore with a 90mm stroke, ~1.6 litres) Im having a problem
trying to figure out what to do about the compression.
Since this is a turbo motor i would like to keep the compression around
9.5:1. The only problem is the head in the ZC has a 43.8cc combustion
chamber. vs 34.6cc for a d16z6. So i either need to get a 11:1 piston or
mill the head and use a 9:1.
Im just not sure if using a high compression piston in a high boost
application is a good idea? Ive heard rumors that the ring lands are higher
in a high compression piston which isnt going to be as strong as a lower
compression one? Am i better off milling the head? Do you have any
thoughts?
thanks,
liam
Old Jul 21, 2003 | 03:08 PM
intekragsr's Avatar
Default Re: milling head or high compresison pistons? (liam821)
I would say neither. Milling the head will be an irreversable process for future sake.
Maybe get a thinner headgasket?
Old Jul 21, 2003 | 04:36 PM
liam821's Avatar
25 Year Member
Default Re: milling head or high compresison pistons? (intekragsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">I would say neither. Milling the head will be an irreversable process for future sake.
Maybe get a thinner headgasket? </TD></TR></TABLE>
Id have to remove 2.25mm (the head gasket is only .89mm in height if i remember)
So its either wack the head 2.25mm (wow) or high compression pistons.
And wacking off 2.25mm im worried about valves hitting pistons and other clearances.
And with high compression pistons i worry about the ring lands and how they react to detination?
liam
Old Jul 22, 2003 | 11:30 AM
liam821's Avatar
25 Year Member
im gonna play bump bump
anybody else?
Old Jul 22, 2003 | 11:34 AM
Sonny's Avatar
What pistons are you planning on using?
Sonny
Old Jul 22, 2003 | 08:04 PM
liam821's Avatar
25 Year Member
Default Re: milling head or high compresison pistons? (Sonny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Sonny
CP 11:1 d16a6 pistons. But if i mill the head i would use CP 9:1 pistons. My end goal is 9.5:1 compression.
Are the CP 11:1 pistons just as strong as the 9:1? I hear the ring lands are different?
liam
Old Jul 22, 2003 | 09:29 PM
swrdply400mrelay's Avatar
http://www.jepistons.com/pdf/2...a.pdf
Could you use D15 pistons for a higher compression, but lower than 11 CR?
Old Jul 22, 2003 | 09:49 PM
Sonny's Avatar
Can you get the specs on their pistons?
Compression Height
Dome/Dish volume
I used Endyn pistons in my D16A1/ZC and fortunately, Larry had all of that info right on hand, so I was able to calculate things exactly.
Sonny
candy eg
Jun 28, 2006 01:38 PM
Techna600f4i
Jun 19, 2006 11:49 PM
Matgallis
Jun 8, 2004 10:20 PM
ITR_1211
Jan 18, 2004 08:09 AM
90da4dr
Mar 2, 2003 05:38 PM
